Question about La Pavoni Espresso Si PAB-16 Espresso Machine
When the pump is activated by the coffee switch the pressure builds up but no coffee comes out the bottom, hot water leaks over the top of the portafilter and runs down the outside.
    Scholar:
  • 36 Answers
Hi there it sounds like the pressurised handle has a blockage in it or your coffee is too finely ground. The handle is spring loaded as well so make sure when you push the handle over to the right that the actual handle comes back to the centre so to open the inside to allow coffee through. If blocked try putting the head of the handle into a solution of descaler.
All the best
LaPavoniBoy
Posted on May 28, 2009
Davey presssure pump when switched on b4 tap is opened the pump does run stop run stop run stop between each cycle small squirt of water escapes from pressure tank at the clamped junction
fix the leak as the pump build pressure switches off , the leak looses pressure pump switches on and so on
fix the leak and the pump will build pressure and switch off until the tap is used
Nov 19, 2016 | Plumbing
Coolant leak
Hose ? The drain valve on the lower radiator ? The water pump has what's called a weep hole built into it. When the water pump fails water weeps out of that little hole to let you know it's bad. I think the ion probably has the water pump onth the front of the engine under the plastic cover ? ( not sure on that ) if it is the water will leak from behind that plastic cover making it look like its coming from the area where the oil pan and that plastic meet. It could get blown around by the cooling fan making it look a lot worse that it is. Check the lower hose and all the other coolant hoses for cracks or leaks as well as the entire radiator area ( sides, top, bottom ) check your rad cap when its cool and be sure the rubber seal on the inside of the cap is good and not cracked or dry rotted. If it is then when the water gets hot and pressure builds in the rad it will leak. When its cold it may not.
Aug 09, 2013 | 2004 Saturn ION
I have a hot water heater that when running seems to build up an excessive amt of pressure. We just replaced the pressure valve because the old one started leaking when the hot water was running for any...
The most likely problem is that the thermostats are set too high. Remove the thermostat cover plates and look to see where the thermostats are set. The range should be between 120F and 135F. Liquids expand with heat so the higher the temp, the high the pressure. Decrease the setting on the thermostat until the leak stops.
The other likely cause is a head of air trapped in the top of the tank. After drawing hot water, it wiill be displaced by the incoming cold makeup water. This will compress any air in the top of the tank. As the water heats, the air will heat and pressure will build - possibly causing the leak. You can purge the tank of air by opening the pressure relief valve until water comes out (which I assume that you have already tried).
Dec 09, 2010 | Whirlpool Water Heaters
Toastmaster 583P leaks after cleaning - water seems to come from pump area around bottom
There are two soft plastic tube from the heating elements, one is intake tube which must fit the water reservor intake plastic well. another one is send the hot water to the top of the coffee maker to shower the hot water to coffee. Anyway is take it apart to find out which is the possible spot cause leaking. Not too easy.
Apr 27, 2010 | Toastmaster 583P
Water leaks when switching on machine ie by build up of pressure
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Feb 21, 2010 | Krups Super Automatic XP 9000 Espresso...
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Not brewing shots, just spewing water out the top!!!
Yup, it sounds like you have a leak !  When the spoon is locked in place, the coffee is preventing (blocking) the water from flowing freely, and it simply finds an easier path, through a hole or loose fitting above the spoon... Depending upon your skill level, you may want to have a look inside the machine and you should be able to see where the leak is.  If it's a hole in a pipe/tube, the pipe/tube will probably need to be replaced (maybe it can be repaired...), and if it's a loose fitting, you can try to tighten it.  It might have come loose due to the vibrations from the pump. Another possibility is that you have a lot of scale built up in the system.  If you've never descaled your machine, you should do so regularly using coffee machine descaler or "CLR" available at hardware stores.  If you've ownded your machine for a while and never descaled it before, run the descaler 4 or 5 times to give it a good cleaning and then do so according to the instructions (I do mine every couple of months but I don't use my machine every day).  If you use unfiltered tap water, the scale will build up more quickly, specially if your local water is "hard".  Consider using filtered water to reduce the buildup of scale.
May 04, 2009 | Starbucks Barista Utopia
Saeco portafilter instructions
When using ground coffee, use coarser grind like the size of table salt grain. Feel the ground coffee for adjustment. Do not tamp, just level the cup with coffee grounds and lock the portafilter into the group ring. Pull the handle all the way to the right and hold. Turn espresso hot water switch on. Hold the portafilter pulled all the way to the right for 5 seconds (pre-infusion pressure builds up to 9 bars). Release the handle at the end of 5 seconds. Espresso shots should be max. 2-Oz. in the cup. For larger quantity, use two shots. For an Americano, add hot water instead of allowing 8-Oz. water to pump through the coffee grounds.
Mar 05, 2009 | Saeco Aroma - Stainless-Steel
Leaking water
Are you losing water from the radiator or expansion tank and need to keep topping up? Did the fault occur before the radiator & thermostat were replaced or only since?
Sep 09, 2008 | 2001 Jeep Grand Cherokee
La Pavoni Espresso Si PAB-16 Espresso Machine Logo
221 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
