Question about Optoma EP739 Multimedia Projector
After running for a while the projector smells hot
  • 13,433 Answers
Hey,
thats completely normal, make sure the fan and ventilation is working properly so it doesn't overheat.
Posted on Feb 18, 2009
I have an Excelvan PH580+ TV projector. When turned on it runs for about 5 minutes and turns off. Smells like it's getting hot. Probably the bulb but I don't see how to change it?
Probably not the bulb. More likely a transformer. Could be a simple as years of dust on the tranformer or blocking the air vent. Is the fan working? Ground the cap before you start touching wire terminals.
May 29, 2017 | The Office Equipment & Supplies
I have a Hitachi CP-X417 projector that keeps blowing lamps. Smells like something is getting extremely hot.
It sounds like you may have a broken or inefficient / blocked cooling fan. Check the air filters and make sure it is very clean and dust free. Also listen to hear if the fan is running at what you think is a normal speed - not irregular or start / stop. If this is all ok then it may be an issue on the d.c power supply to the fan - don't spend more money on a bulb until you check this out.
Mar 18, 2011 | Hitachi CP-X417 Projector
INFOCUS LP350 WILL NOT POWER ON, SMELLS LIKE A CAP EXPLODED.
did the projector make a popping sound if so that lamp has shattered. the smell would be mercury and the projector will not switch on until the lamp has been reset.
depending if the projector was hot the hot glass may of stuck to the lcd screen so it may not work again.
Feb 09, 2011 | InFocus LP 350V Multimedia Projector
My Sony VPL CS1 projector was working on Monday and is not working on Wednesday. Smells hot but fan is running. Light was on but now it is not on and the Lamp/Cover light is on.
hi,
check the lamp cover is it open or not. there is switch for sensing, is the lamp cover is open or not. may be it became faulty. also check the lamp is it burned or not . if found burned replace it.
ok
Dec 22, 2010 | Sony VPL CS1 Multimedia Projector
Becomes very hot within minutes of turning on.
There is a 400 watt mercury vapour lamp. Provided the fan is running it should get fairly warm to the point of almost too hot to hold your hand on. If you can smell burning plastic smell you should refer the unit to local service department for testing.
Sep 29, 2009 | Dell 3200MP Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
Projector quit working and started smoking
Unfortunately your motor is toast- it also provides the low voltage for the remote control. Motors are no longer available new so your best bet is to try to find an old projector on the sued market. you can often get them as cheap as free to $25.00. If it's working, just use it. If there are other things wrong but it's motor works, you should really have the identical motor- not all were the same electrically.
Dec 18, 2008 | Kodak Office Equipment & Supplies
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
Projector smells hot
I have a Dell 2400mp 3,000 lumens. After you pull out the old lamp, find an air chuck, now be carfull, you want to make sure that there is no watter in the air line, trust me what can go wrong dose.<---. Now make shure that the air pressure going into the projector fan is not to much, for example 120psi would rip your projector appart.This was the best cure for mine, be carfull with those air cans also, they work well for alot of stuff, but projector fans are a little harder to get to. If you use an air can make shure to hold it in the position it would be if it were on a counter or sitting some other place. And do not put the screws on very tight. hammlet3@gmail.com
Oct 12, 2007 | Sony VPL PX31 Multimedia Projector
Optoma EP739 Multimedia Projector Logo
240 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
