Question about Southwestern Bell (S60802)
Need to program the memory on phone
Memory programming
need instructions on how to program phone with memory
How do I set the 10 dialing memories?
Posted on Jul 31, 2009
Does anyone know exactly what the instruction at 0x755aee49 referenced memory at 0xa3ffff24 the memory could not be written error is and how to resolve it.
You launched some program, and Windows chose to load some of the program at the first address, and then the program tried to write some bits/bytes/words/data to the second address, but Windows has allocated the memory at that address to some other program (or to Windows itself), and Windows is "blocking" the program from overwriting at a location that is outside the bounds of the location (in memory) of the program.
Mar 04, 2015 | Computers & Internet
Radio Shack telephone Cat# 43-3091 Need phone setup instructions incl. programming memory button
If you mean the Radio Shack 43-3901 then you may download a copy of the manual here.
Apr 06, 2012 | Lands Phones
I have a Panasonic Easa-phone Model KX T-3135. I need information on how to program the memory to use the automatic dialer keys.
Panasonic ESA-PHONE - KX-T3135
Program instructions for the "Automatic Dialer"
On the right side of phone set the 'Memory' switch from 'Set' to 'Program'
If programing the upper entry of a 'Automatic Dialer' buttons:
Press the button - enter the phone number as it needs to be dialed - press the 'Memory' key on the left side of the phone's face.
If programing the lower entry of a speed dial buttons:
Press the 'lower' button on the left side at the bottom of the 'Automatic Dialer' pad;
When all entries are complete, on the right side of phone slide the 'Memory' switch from 'Program' to 'Set'.
May 03, 2011 | Cell Phones
I have a Panasonic KX-T2345 and I need Info on programing memory stations and using "call hunt". Thanks
PanasonicKX-T2345 program buttons
To Program
Push Buttons
1 Memory slide Sw Under
Lower RT lip to Program
2 Memory light lit
3 Station button Press (Beep)
May want to write name 1st
4 Memory light goes out
5 Dial Phone number
6 Memory button Press
(Long Beep)
7 Memory light lit
...repeat 3-7 for more Ph #
8 Memory slide Sw Under
Lower RT lip to Set You are Done
PanasonicKX-T2345
Mar 21, 2011 | Panasonic Lands Phones
My nokia wont send texts it keep saying general memory full close applications..... How do i get to the applications 2 close them
It will be good to remove the memory card and check for errors/virus Use a good antivirus to scan and clean the memory. Remove off the bad files and keep back only safe ones.
remove battery and keep away for 15 minutes, then put back memory and battery.
Now clear out all the SMS, both text and multimedia, from the phone.
If possible reset the phone to default factory settings by using the phone settings- reset factory settings- type 12345.
Once cleared the phone should work or else there can be fault in the phone software which may need the assisttance of Nokia.
Hope this advice helps.
Aug 29, 2010 | Nokia N95 Cellular Phone
After many years have misplaced the instruction manual for our Vista 200. Need to know how to set up names and numbers for the automatic dialling feature. tdijimmy@hotmail.com
First, ensure the display is bright enough. If it is not, press successively on the "Brightness key" that is located on the top of the phone above the "Memory key". You have 8 brightness settings. Note that the "Brightness key" has no label.
You are now ready to start programming.
1. Press the "Memory key". It is labelled "Memory" and is located above the "Memory keys" numbered 1 to 10 on the right-hand side of the phone.
2. Press the "Memory key" you want to program. (1 to 10)
3. Enter the number you want to program using the "Dialling keys"
1, 2, 3,
4, 5, 6,
7, 8, 9,
*, 0, #
4. Once the phone number is entered, press the "Memory key" again.
5. Now enter the "Name" for the phone number you just entered. To do this, you press the "Dialling keys" as follows:
For A press the "2" key once,
For B press the "2" key 2 times,
For C press the "2" key 2 times,
For Q press the "7" key 2 times,
For Z press the "9" key 4 times.
Use the same for all letters.
To go to the next letter, press the "Right arrow key".
For a space, press the "Right arrow key".
6. Once the name is entered, press the "Memory key" one last time. You are done.
7. To test it, press the "Memory key" you just programmed.
Oct 19, 2009 | Bell BE-412CID Corded Phone
Need instructions to program Living Solutions Speakerphone ATC-355
living solutions desktop phone (model unk) programing.
turn on with speakerphone button
hit store button once
enter phone #
hit memory button ( where number is to be stored) once
hit auto button once
to dial stored #'s
kift reciever or turn speakerphone on
hit auto once
hit memory button (where # is stores) once
wait for completion of call
Sep 19, 2009 | Lands Phones
Need help programming autodial feature on my ge-27923-ge cordless phone
how do you change GE Model 27923 2.4 GHz cordless phone from pulse dial to touch phone dial? I lost my instruction manual Thanks
Apr 15, 2009 | Lands Phones
I need programing instructions for a Panasonic Easa-Phone model KX-T3170
For the onetouch buttons 1)push program untill memory light is on. 2) push desired onetouch button,
dial the phone number. 3) push auto button 4) when done press program button.
Feb 28, 2008 | Panasonic Lands Phones
Address book disappeared
I could not find the exact manual for your phone, but this one looks close and has instructions for programming the memory: http://www.conairphone.com/IBs/caller_id/cid200.pdf It says: BASIC MEMORY PROGRAMMING The CID200 comes with 10-memory dialing. NOTE: Your local phone company restricts the time you can have the handset off the base (off-hook). YOU SHOULD PROGRAM THE CID200 MEMORY WITH THE LINE CORD UNPLUGGED FROM THE WALL, IF YOU ARE GOING TO PROGRAM MORE THAN ONE PHONE NUMBER. Press [STORE] to enter memory store. Press the keypad to enter the number that you want to program. Press [STORE]. The ?MEM? will be displayed on the right corner of LCD. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. Copy from the Caller ID to Telephone Memory Press [Up Arrow] or [Down Arrow] until the Caller ID memory location to be copied appears on the LCD. Press [STORE] twice to enter memory store. The ?MEM? will be displayed on the right corner. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. If no key is pressed within 20 seconds, the LCD will return to ?Answer-Ready? mode. Repeat the above steps to store a different number in the same speed dial location, or to store a new number in a different speed dial location. NOTES: ? Pressing [PAUSE] will place a 4-second PAUSE into the number. Which may be required for accessing special phone services. ? You can store a number with up to 16 digits maximum. Only the last 14 digits will be displayed.
Mar 15, 2007 | Conairphone CID 244
Southwestern Bell (S60802) Logo
122 people viewed this question
Top Southwestern Bell Computers & Internet Experts
David Payne
David Payne
Are you a Southwestern Bell Computer and Internet Expert? Answer questions, earn points and help others
