Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Flashing light and laptop will not turn on - Fujitsu Siemens AMILO Pro V2010 Notebook
The "on" light on the front of my sony Vaio laptop continually flashes red when laptop is turned off
My question is the laptop turned all the way off when you go to shutdown do you click shutdown? Because it may show this light if the laptop is not turned all the way off. Also does it only do this when its plunged in? Some time there is a light to indicate the laptop is charging.
cheers best of luck
Feb 18, 2015 | Sony VAIO Computers & Internet
My toshiba computer has turned off and a red light flashes when I try and turn it on again
Sounds like there is no power to the laptop so teh laptop has gone into hibernation. Make sure that the laptop has working mains power.
Dec 10, 2013 | Toshiba Satellite Computers & Internet
There's a batterie light flashing what does it
When you connect your laptop to a power source to charge it using a charger, the battery light will start to flash in RED color. It will turn to GREEN when your laptop is fully charged, so you can remove your charger from the power source.
Jun 15, 2013 | Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Compaq nx6110 PC Laptops: When i turn it on the lights flashes then goes off...
Which light flashes? If it is the battery light then perhaps your battery is empty?
When plugged into your PSU does the power light turn on? If not your PSU may have broken or the plugs fuse may have blown.
Other potential causes could be your RAM, CPU or even your system board. Check the RAM is correctly seated, if two modules are installed try removing one.
Hope this helps, www.PuterCare.com
May 17, 2010 | HP Compaq nx6110 PC Laptop
When i turn on the laptop the lights under the the screen flash
Hi from what you are describing it looks like the laptop heat sink (fan) needs replacing or the motherboard itself needs replacing
I would recommend that the laptop be booked into a reputable repair firm to investigate further
Feb 10, 2010 | IBM ThinkPad T40 2373 Notebook
I have a laptop and there seems to be a light currently flashing orange along the front. Ive searched everywhere to find out whats happened but the laptop won't switch on at all. Its a toshiba Prestege...
The flashing light on the front of your laptop is a low battery warning. There probably isn't enough power in the battery to turn on the laptop. You need to plug in the ac power adaptor and let the battery charge until the battery light turns from 'orange', to 'green'.
May 02, 2008 | Computers & Internet
Toshiba A25-S207
That flashing light indicates that the laptop is not getting power, check and test your power cord. That light should be light solid when plugged in. good Luck
Sep 18, 2007 | Toshiba Satellite A25-S207 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
170 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
