Question about Brother FAX-575 Plain Paper Thermal
I'm not able to receive faxes
Display shows DR mode (what does that mean?) and also it says "not registerd" and I don't know how to register it. Please help!
  • 3 Answers
I figured it out by pressing the Receive Mode button and changing the selection from Manual to Fax.
Posted on Feb 19, 2009
How activate auto answer?
1 Press {AUTO ANSWER} repeatedly to display the following.
FAX ONLY MODE 3 RINGS
The display will show the ring setting in FAX ONLY mode.
The {AUTO ANSWER} light is ON.
2 If you wish to change the ring setting, press
{A} or {B} repeatedly to display the desired
setting, and press {SET}.
How faxes are received
When receiving calls, the unit will automatically
answer all calls and only receive fax documents.
Mar 08, 2012 | Panasonic KX-FL611 Plain Paper Laser Fax
Intellifax 2820
DR mode means that the distigntive ring feature has been activated so it will not let you change receive mode. You need to turn off DR first. Press menu/set then 2, 0, 2, then press the down arrow till you see distigntive off then press menu/set.
Now you should be able to change the receive mode to fax only!
May 29, 2010 | Brother IntelliFax-2820 Laser Fax
Can't set mode to receive fax, read through manuel says DR mode in use. fax does'nt pickup when a fax or call comes in stuck in manual.
DR MODE is in use means that your machine is setup with the distinctive ring feature, to turn it off follow the directions below.
Turning off the Distinctive Ring
1 Press Menu/Set, 2, 0, 2.
2 Press ▲ or ▼ to select Off.
Press Menu/Set.
3 Press Stop/Exit.
Then you will be able to change the receive mode.
Apr 16, 2010 | Brother MFC 210C All-In-One InkJet Printer
I am unable to receive fax. I have tried to fix
try this go into maint. mode * 2 8 6 4 quickly. then hit 9 twice. it resets with out losing any quick dials or tti
Apr 12, 2010 | Brother MFC-8440 All-In-One Laser Printer
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
I cannot receive faxes. The machine rings, the
check to see how the rx mode is set up as it may be set to manual it should be auto.. this means if a fax comes in you will have to lift phone or pressthe start button to receive the fax in manual mode whereas the auto or fax mode will turn the fax on automatically
Aug 13, 2009 | Office Equipment & Supplies
MFC 465 CN - says FAX in DR Mode...What is that?
DR mode is distinctive ring, you have to go into fax setup and step through the options. If you go to print reports and select user settings the report will tell you what it's set for and the options are found in the same order they are printed.
Jun 24, 2009 | Brother MFC-465CN InkJet Printer
Mfc 8460n dr mode in use
The message DR mode in use or BT Call Sign On will appear on the display of the Brother machine if you attempt to change the receive mode from Manual to another mode when the Distinctive Ring feature (BT Call Sign) is turned ON. If you want to change the Receive Mode, set the Distinctive Ring feature (BT Call Sign) OFF.
  1. Press Menu or Menu/Set.
  2. Select Fax => Miscellaneous or Tel Service => Distinctive or BT Call Sign.
  3. Press the Up or Down Arrow key to select off. Press OK or Menu/Set.
  4. Press Stop/Exit.
Jul 16, 2008 | Brother Office Equipment & Supplies
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Brother FAX-575 Plain Paper Thermal Logo
111 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
