Question about Kenmore 95002 / 95004 Electric Kitchen Range
Oven temperture is incorrect
Kenmore glass top. I replaced oven sensor to no avail/
  • 107 Answers
If your sensor has a quick connect, try eliminating it and hardwiring the connection. Sometimes the connectors wear from the heat. If this doesn't work, then the control is bad.
Posted on Mar 16, 2009
I have a Kuppersbusch microspeed plus (EMWK9600.0M) was in the house when we moved In. whilst using it in microwave mode I heard a bang and the internal glass door has shattered.
The glass will break if the food being heated is not covered and fat/grease heats up to flash point on the glass or there is a cut in the glass or the food banged against the glass or the glass was stressed by an incorrectly fitting door.
A new door is possibly available or glass.
May 17, 2017 | Kuppersbusch Ovens
Element in oven gets red hot, burns food being baked, will not shut off unless I unplug oven. how to fix?
You need a new thermostat or oven sensor. These people are pretty good but I am have trouble find details on the model number you gave. This gives an idea.
http://www.appliancepartspros.com/kenmore-range-cooktop-oven-fuse-sensor.html
Another place here
http://www.partselect.ca/Model-Number-Locator+8+repair.htm
Nov 15, 2015 | Kenmore Kitchen Ranges
Glass top on my Kenmore oven shattered- is t repairabe
Probably cheaper to replace whole oven try insurance if u have its an accident so insurance may pay if u have.
Oct 16, 2014 | Kenmore Ovens
How to fix kenmore f 3 code?
f3 code is the code for the oven temperture sensor that control the oven temperture need be replace ok
Dec 13, 2017 | Washing Machines
How do I change the lightbulbs in the oven
Make sure the oven is off and cool (turn off the circuit breaker). Wear a leather glove to protect your hand. Depending on your model, there may be a glass shield held by a metal holder over the lamp. In the case of a unit with this holder, press on one side to release the shield and remove it. Remove the bulb by turning it counter-clockwise. Replace with a 40 W appliance bulb (turn clockwise). Replace the glass shield and the holder. (On some oven models, the shield will twist on and off like a bulb.)
There are several models of Kenmore 47783 Ovens; manuals are available here: http://www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+47783 .
I hope this helps.
(please note: never operate the oven without the shield in place if your oven has one.)
Dec 12, 2010 | Kenmore 47783 Electric Single Oven
Don't know the model number. What does F-3 mean when it flashes when I try to turn on the oven temperture
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Oct 06, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore 665-9580 error code ''E1 F2''
sounds like you need to replace the oven temperature sensor.
Nov 07, 2009 | Kenmore Kitchen Ranges
Kenmore Electric oven 91141065791
Failure
Code
Condition Check/Repair F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC) F3 Open oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F4 Shorted oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC) F7 Computer logic interrupted (lock motor) Replace Electronic Range Control (ERC) F8 Computer logic interrupted Replace Electronic Range Control (ERC)
Oct 23, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 95002 / 95004 Electric Kitchen Range Logo
91 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
