Question about Whirlpool GEW9250 Electric Dryer
My Whirlpool Electric Dryer got extremely hot yesterday after a load of clothes. Today, I tested it and when I pressed the START button it "buzzed" (like it was trying to start) and then I smelt a burning smell. It scared me, so I unplugged the dryer. Help?
  • 547 Answers
Replace the belt
Posted on Feb 18, 2009
Whirlpool Gold Calypso Sensing not drying. Dryer worked for three loads today and now when i close the door I press normal dry and then the start button but it won't start. To the right the...
underneath the lint trap is the sensor, it is dirty. You will need to clean it, just be gently as if not you may break it, when you look down the lint trap it has two screws. Here is a web site that will help with the dissemblance of the dryer :
under the heating element it says open up a dryer just click on that Good Luck Tim
Feb 19, 2011 | Whirlpool GEQ9800P Electric Dryer
We bought our dryer new 2.5 years ago and up until today it's been working great. ran it yesterday with no problem. put clothes in it today, pressed the start button and it made the buzzing noise as if...
Dryer motors are common for lint build up in the motor at the motor switch. If you get the dryer apart again use a vacuum and small paint brush or compressed air and blow out the motor. Make sure you clean your external vent frequently and do not use flexible vinyl ducting. Also, make sure you check the blower for any obstructions as this will also prevent the motor from starting.
Jan 07, 2011 | Amana NED5200TQ Electric Dryer
I tried to start the dryer (whirlpool LE5700XK or the LG5701XK, not sure which) and when I hit the start button there was a loud buzzing noise, but no start. I turned the dial to the off position, and then...
Could be a couple things, depending on the buzz you are getting, if it's a buzz from the board like an alarm, it could be a door switch, if it's an electric sounding humming buzz it could be something stuck in your blower wheel like a sock
Jun 24, 2017 | Whirlpool Dryers
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer was running with full load of clothes. Heard a loud pop twice, ran back to the laundry room and smelled like something burning. Turned dryer off, and now it won't start back. Also, the very top of...
Well it sounds like a sound I have heard... forgetting that I had a cigarette lighter in my pocket and having it explode from the heat in the dryer. But you say you heard two loud pops?
Once everything cools down, check again and report back... does the dryer not turn on at all? Does the light come on when you open the door? Does it buzz when you push the start button? Stuff like that.
Jul 27, 2009 | GE DBXR463EDWW Electric Dryer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool dryer (electric)
did the button click when you pressed it when it worked fine, if it doesn't click now then you need a new button switch, which should be fairly cheap and fairly easy to replace yourself with care if the button should be pressed to start without normally clicking and needs to be pressed to restart each time you open the door then the start relay could be faulty, sound complicated but not the same fault hope i have been of some help, if so please rate me
Oct 04, 2007 | Whirlpool LEQ9858P Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
126 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
