Question about Ricoh Office Equipment & Supplies
Text boxes. I am having troubles printing visual documents in colour on our office Ricoh Aficio 2232C. It keeps putting boxes around areas outlined by text boxes in Photoshop and InDesign. These boxes do not show up with any other printer or copier.
There are a few different drivers for this machine: RPCS (ricoh's own), PCL5c, and PCL6. I have had incidents of strange output, often with the RPCS driver, and find that the PCL 5c works best. Identify which you are using, and maybe try another.
here is a link for the driver download page. Copy the line into your web browser:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/c32_38/c32_38en.htm
Posted on Feb 18, 2009
Colour not working
have you check toners to see if they are not empty ?
Apr 21, 2013 | Ricoh Aficio 2232C Color Copier
Ricoh Aficio 2232C Error Message SC393-02
I had the same problem after transit of copier. Try removing the yellow developer unit and give it a good shake. You may need to do it with the other units too.
Apr 16, 2013 | Ricoh Aficio 2232C Color Copier
Printing page going to pause mode
check paper size setting and also auto paper size setting
Jul 28, 2012 | Ricoh Aficio 2232C Color Copier
Our Ricoh C4100N prints very slowly. We print documents that contain a fair amount of color graphics. Not uncommon to be sending a Word document size of 35MB and it will take more than 20 min to...
Yes but how many pages in a 35MB doc that takes take more than 20 min? How complex are the colour graphics, please?
That's meant to be capable of 25ppm according to cnet.com/products/ricoh-aficio-spc410dn/specs/
D'you know how much RAM it has? That page said it comes with 256MB but can take 512
Nov 04, 2017 | Ricoh Aficio SP C410DN Laser Printer
I have a Ricoh 2232c copier. The ink is fading. I changed a drum and cleaned the machine. I was having troubles with the waste toner lines being clogged but I cleaned the lines and it seems to be...
drums and dev units are meant to last 80 k so check the age.2 have u cleaned the optics? very very important.3 do auto colour calibration in system menu 123 button.or u should be doing it at least 1ce a week.oil has nothing to do with it.
Apr 19, 2010 | Ricoh Aficio 2232C Color Copier
Describe your ricoh aficio 2232c manual copier internal tray problem solving Problem display screen says internal tray open cholland@shawu.edu
just take a air blower and flow the area from where the paper comes out ur internal paper tray sensor is dirty
Jan 22, 2010 | Ricoh Aficio 2232C Color Copier
Reset Duplex Unit Correctly on Ricoh 2232C
Hi There,
The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
Scott K.
Jan 28, 2009 | Ricoh Aficio 1085 Laser Printer
Stops Printing Entire Page After Around 50 sheets
First, check the text in your records for odd characters. It is sometimes possible in data entry to hit a ctrl-"letter" combination that embeds printer codes in your text and these are invisible in many cases to the application. The easiest way is to break up your print job to sections of records and see if a particular record consistently causes an error.
If your sure however that the printer is the problem...
Then I would check the RAM. The printer has 128MB upgradable to 512MB. Normally you can pull the ram and run jobs on the internal memory, but in this case you would need to swap it out.
Jun 05, 2008 | Ricoh Aficio CL3500N Laser Printer
63 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
