Question about Car Audio & Video
No sound the led light comes on for 5 sec then flashes for 5 sec then it just keeps repeating i checked all wires
  • 58 Answers
Check ur fuses box for a blown fuse or if ur amp has a fuse check that as well and if blown u might have to change ur fuse if not ur amp is blown
Posted on Feb 19, 2009
Picture and sound come and go on antenna or dvd
Try another lamp. Error 5 is Lamp power supply, but its usually always the lamp bad.
Mar 27, 2014 | Sony Grand WEGA KF60WE610 60" Rear...
LG dlg0332W gas lights up for 4 seconds and goes out for 5 minutes and repeats
It sounds like a plugged or restricted exhaust vent or blower wheel might not b spinning, check blower and belt:)
Nov 30, 2013 | Dryers
It was working fine until yesterday. It shut itself off. I powered it back on and befor the screen could come back on it shut itself off. I checked cables and uplugged it for 24 hours. The first time...
Hi Daniel,
Please check if you can access the "error code operational check" to narrow down where the fault came from.
How to enter to error code operational check.
Note : The TV must be in shutdown and not have been switched off. When the TV is switched off, the error code automatically resets to 12 (no error).
Press the buttons on the front panel "Input/Device" and "Menu" at the same time and hold it for 5 sec, activate the error code mode. The LED light will flashes denoting a two digit error code.
Example : if the error code is 22, the led will flash two times pause and then flash two times and will repeat the error code for five times.
If you can't access the error code operational check , please let me know the exact pattern of the flashes of the led light and its color. Check if it will continually flashes green to give you the caused of the symptoms and best solution.
Good luck and take care.
Nov 15, 2011 | Mitsubishi VS-50805 50" Rear Projection...
Green timer light blinks and then lamp light blinks.. tv will not start up.
You probably need a lamp. Check the code by holding menu and input for 5 sec. If you need a lamp the led will flash 6 times pause then flash 6 times again. The code will repeat several times if you miss the first few flashes. If the code is different, let me know what it is and I can help you. Thanks.
Jul 05, 2010 | Mitsubishi WD-65733 65" HDTV
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Dishwasher will not run clean light keeps blinking
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 10, 2010 | Whirlpool Dishwashers
Thomson scenium LED error code 45
When i turn it on red light flashes 3 times then 1 time, this keeps on repeading, no sound, no light
Sep 30, 2009 | Televison & Video
System won't power up
ITS BROKE - YOU HAVE TO GET IT FIXED OR THROW IT OUT. SAME THING HAPPENED TO US -UNDER WARRANTY BUT WE HAVE TO PAY THE $80 TO SHIP IT TO THEM. WHAT A FARSE.
Aug 04, 2008 | Olevia LT42HVi 42 in. LCD Television
Car Audio & Video Logo
145 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
