I need a manual for a Linotype Hell Rip PostScript RIP 50
Hello...I am looking for a manual for a Linotype Hell Rip PostScript RIP 50 which is a Raster Image Processor for a prepress plate generator for a Heidelberg GTO46 printing press.
Many Thanks,
Barry
2 Suggested Answers
SOURCE: IBM Laser Printer 4537-N01 900.43 service RIP software
I rebooted with the network cable out.. Once up again I plugged it in and off it went.
Posted on Jul 23, 2008
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
Posted on May 04, 2009
You can do this using Windows Media player and Rip the CDs ...does this mean.. to burn the cd onto the computer?
Hello, to Rip a CD to your computer means to convert the audio on the CD into a format that your computer can play, such as mp3 or wma. Windows media player can rip CDs to both formats and stores them in your music folder. Just insert your CD and the option to rip should pop up.
To Burn a CD means the reverse, to transfer music files from your computer to a CD. Media player does this a well, just click the Burn tab to begin.
Thanks for asking, and using FixYa
Jul 23, 2011 | Computers & Internet
Hi i have copied music from my cd but when it says to transfer to external devise it shows on mp4 but there is nothing there. not sure what i'm doing wrong.
You cannot drag and drop music from an audio cd to your computer. You need to rip it. Use itunes or windows media player. Look for the option to "Rip" music from the CD.
Rip using media player:
Mar 23, 2011 | Laser MP4-V970 MP3 Player
Need a rip fence
Howdy, Here is the ordering page link with the rip fence (called edge guide, part number 2610997206 by Bosch) from Bosch:
https://www.boschtoolsservice.com/Search/QuickPartsOrder.aspx
I would recommend looking in a pawn shop or ebay as the rip fence is nearly 100 dollars as a replacement part.
Hope this helps a bit:)
Regards, Farmerbear
Sep 08, 2010 | Bosch 4000 - 07 Electric Table Saws
The rip on the copier is flashing FF and I am not able to print. What can I do to solve this problem?
Hello. The FF is a hexadecimal number that means the rip did not boot properly.There are buttload of reasons why this my be but lets try this. Power off the copier and the Fiery emulator (rip).Power on the copier only and let it reach aready condition.Then energize the rip and watch the same display that showed the FF.It may take a minute or two as it goes thru its boot/diagnostics,but we hope you dont get the FF again.Now I am assuming that what we are talking about is a previously configured system that had been working fine until recently.If this is so,and the rip does not operate correctly after the directions I just gave then you probably need to re-load the rip's system software.
May 27, 2010 | Canon imageRUNNER C3220 Color Copier
Speaker cone is rip
that sucks. Expensive sub. If its under warranty go that route.
If its not under warranty, you can repair it with epoxy.
Go to Lowe's and get a 2 part epoxy. Mix it and seal up the crack with the epoxy. Put it on thick because the sub is going to vibrate it like mad and it needs to hold up.
Jan 21, 2010 | Jl Audio 13W7 Car Subwoofer
How can i recording music for my new mp3
There are of number ways to get Mp3's. You can use W**dows Media player - open Media player and right click at any part of the top bar click on tools and then click options, look for the Rip music tap and click that. Now look for rip music to this location chose a folder to put your music in. Then look at the format button and chose mp3. Click the Rip CD when inserted and close it all up. Then put in a cd you want to rip, then once it is thru copy your new mp3's onto your MP3 player - done.
Dec 04, 2009 | Nextar MA933A MP3 Player
Will a Linotype Hell Ultra 2 Saphir run on a pC?
Yes. Just got mine running on Windows ME. Problem is getting the SCSI set up. Once you get that done, I used Vuescan (http://www.hamrick.com/) and it works. Slow, but functional. I have yet to get scans of the full scanner screen (10 x 14 inches). But 8 x 10 is working fine.
Sep 10, 2009 | Heidelberg Linocolor Saphir Ultra2 Flatbed...
The printer Lexmark C532c is not printing.
Try using the PCL driver or select the "Disable Postscript Passthrough" under
Printing Preferences->Other Options->More Options->Postscript
Nov 12, 2008 | Lexmark T644 Laser Printer
Lexmark Colour C752 108 service printhead error
You are correct, Below is that section from the manual. Before you follow this, i've found in the past that the cable connector is not seated properly on the rip board, so check this first.
If you require any of the instructions on replacing the printhead or board let me know.
Yellow Printhead Lost Hsync
Check for the correct installation of the all the cables to the RIP
Board assembly and to the Printhead assembly; J2, J3, and J4 on
the RIP Board. Go to “RIP Board” on page 5-11. If the cables are
connected correctly to the RIP Board and to the Printhead
assembly, replace the following FRU:
“RIP Board” on page 4-11
If this does not fix the problem replace:
Yellow Printhead Assembly - Go to “Printheads” on page 4-33.
Note: Whenever a printhead assembly is replaced, it is necessary
to perform the “Printhead Adjustments” on page 4-1.
Jun 03, 2008 | Lexmark C762 Laser Printer
489 people viewed this question
k24674
