Question about Nakamichi AV-7 Receiver
I have two powered speakers, and Ii just bought an amplifier. Can I still connect the powered speakers to the amplifier?
You are charging me to tell me how to fix it right?
And you want me to tell you how did I fix it for free? I Don't think so.
Bye...........
Posted on Feb 26, 2009
Hello I recently bought an Hyundai Iload and want to know if I can connect a subwoofer to the factory unit?
Yes, you can. You will need a hi/lo converter to use the high signal from one of your vehicle's speakers and convert it to a low signal for an amplifier. Your will need an accessory power source (switched with the car's ignition or accessory on) to act as a remote turn for the amplifier. You will need an amplifier kit. The kit usually comes with a power wire, ground wire, remote turn on wire(blue), RCAs to connect the converter to the amp, a fuse for the power supply at the battery and speaker wire to connect the amp to the sub. Now, all you need is the sub.
Aug 13, 2012 | Car Audio & Video
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
My subwwofer does not seem t power on .....it is also not picking up a signal...... can you help with this
Hi slikrik
Please check your external connections, power if everything is ok then.. First please confirm when did you purchased this Active sub., This sub system is having 5years warrantee on Speaker and 3year on Amplifier. Hence, if you are the due date please give it for free checkup and replacement for parts.
-sai kumar
Dec 28, 2010 | Definitive SuperCube II 8" 1250-Watt...
Kenwood Receiver VR 806 turning off
Sounds like the music amplifier is different to the tuner audio amp. The music amplifier is now looking at an unbalanced impedance which is less than it should be. Therefore the output chip of the music amp has more current through it than it wants so it gets hot and shuts down.Put a four ohm wirewound resistor ( from Radio Shack ) in series with each surround speaker to reduce the current flow through the amplifier output.
Apr 09, 2010 | Kenwood VR-806 Receiver
I have a KLH bassbite II sub, not sure how to connect it to my receiver. Can you help? There are 4 wire amp inputs and 4 speaker wire outputs which I am assuming are right and left channels. There are...
Forget the 4 wire inputs on the sub as you have pointed out. use the low mono input only.this can be plugged into any audio out connections at the amplifier.so it is one rca/low wire from sub to amplifier then plug in power cord and adjust volume as desired.
Mar 06, 2010 | Audio Players & Recorders
Getting buzzing sound from speaker but can here sound from them.
You could have an earth loop which causes a hum/buzzing sound.
Is your computer and powered speakers plugged into different mains?
Connecting amplifiers and speakers to different power sockets will create earth loop problems
This can be fixed by using a single power board connected to a single mains power socket, then connecting all the computer components and powered speakers into this one power board.
Oct 31, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Connect cheap speakers to a new amplifier
You need proper speakers,pc speakers uise mini headphone jacks,wrong termination for an av amp
Dec 21, 2008 | Plantronics MX10 Computer Speakers Use w/...
Installation
If you've got a standard 4 speaker system (2 front, 2 rear), your best option is to connect both left speakers to the left channel amp output and both right speakers to the right channel amp output. The only thing you lose is the ability to fade the speakers front to back.
Mar 04, 2008 | Legacy - American II: 2 Channel 1200W...
Nakamichi AV-7 Receiver Logo
95 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
