Question about Casio G700D-1AV G-Shock Watch
My husband's G-Shock broke at the plastic/rubber piece that connects the wristband to the watch face. I need to get that tiny piece replaced. Where?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
Order new watch band on ebay and have watch person install as it is very tight.
Good luck,
Techjoel
Posted on May 11, 2009
4 Suggested Answers
dmbgo
  • 58 Answers
SOURCE: How to replace the rubber wristband of a luminox watch
If you have a new wristband, there is a spring loaded lug where the band joins the watch, use a sharp knife or jeweler's screwdriver to slide the lug from the watch
Posted on Jun 22, 2009
  • 2501 Answers
SOURCE: Adidas adp 1040 wristband replacement
I can't find any info on strap replacement on their web site, so I suggest you find your nearest store and speak to them about it.
You can find your nearest store by going to "www.adidas.com" and clicking on "store finder" at top.
Posted on Mar 03, 2010
Testimonial: "I live in Brazil, but I bought the watch in U.S. As per your suggestion, I'll try their website and look for the nearest store. Thanks for your help!"
mcdevito75
  • 1970 Answers
SOURCE: I need user manual/instructions for Slazenger, model not known
mcdevito75 here, You can visit a small watch repair shop in your area for info, as some watch makers only deal with their watches commercialy.
Posted on Jun 27, 2010
Replacement band
You may try looking on ebay for the wristband.
Thank you,
Marcelo
Oct 23, 2013 | Casio G-Shock GW500A-1V Wrist Watch
Watch face moves around
Chances are the plastic piece around the movement of the watch broke or is out of place. I suggest taking it to the jewelry store and have them correct this for you. It should not be too much money to fix this. The other option is to pop the caseback open to see if the plastic piece is stil in place if not then you can easily put in place again. However be carefull not to scratch the caseback and sometimes it's hard to insert the caseback on again. You would probably need a tool.
Feb 24, 2013 | Raymond Weil Watches Nabucco...
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    Jun 27, 2010 | Watches
    Jun 19, 2009 | Navy Seal Luminox Dive Watch
    Zoppinni mother of pearl round watch
    You just need a new pin which is relatively inexpensive. Any jeweler should be able to help you with this.
    Jan 11, 2009 | Zoppini Mother of Pearl Round Face...
    I just replace the battery for a casio watch 2315 but it still does not work
    Hi, I just encountered the same problem today as I was changing the battery and I found the solution. First make sure when you are changing the battery that the watch stem is pulled out; then after the battery has been replaced, and before you put the gasket and back on you will need to "reset" or "hotwire" the battery ....you are going to likely need a magnifying glass to find a tiny ac symbol on the back of the watch (without the back cover replaced)...just next to the ac symbol is a tiny hole. Take a piece of wire, or in my case I used an unfolded paper clip, and put one end of the wire in the hole and the other end on the back of the battery (the +/positive side should be facing up). Leave the wire in contact with the ac/battery for 5 seconds, then remove. Next replace the rubber gasket, then the back and the screws. Lastly, push in the watch stem. Your watch should now work. I found out through considerable research that almost all digital watches will need that "hotwiring" step performed after the battery is replaced.
    dcraigpa
    Dec 21, 2008 | Watches
    Casio G700D-1AV G-Shock Watch Logo
    253 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
