Question about Grohe Eurosmart, 3-hole Roman Tub Filler and Hand Shower w/ StarLight Chrom
Diverter valve does not work correctly.
Eurosmart 3-hole tub filler w/ hand shower
When turned on, water flows from hand shower and diverter knob is set in the up position. Pushing down on the knob diverts water to the spout but when released the knob pops back up and water flow is through the hand shower.
The knob does not default the water flow to the spout.
In other words the water flows only from the hand shower and will not flow from the spout unless the knob is held down manually.
  • 297 Answers
The connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
Old Moen shower diverter
You will have to replace the shower diverter button. Remove the handle, remove the faceplate, and the diverter will screw out. Any plumbing supply that carries Moen products will have a replacement button for your valve
Feb 23, 2014 | Moen Home
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
System won't switch to shower
You need a diverter in your spout. The spout will screw off and the new one will screw on. Lift the ball while the water is running and it will divert the water to the shower.
Dec 14, 2012 | American Standard One Handle Tub & Shower...
Water flows from shower and tub when it should only be the tub
you need a new diverter valve, actually it's inside of the spout/filler for the tub, a very simple fix. It isn't holding all of the way.
Nov 24, 2012 | Home
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
I bought a tub/shower valve system from lowes. When I turn on the faucet for the tub, the water comes out the tub faucet and the shower head at the same time. Is this a defective valve? Everything seems...
it sounds like the tub filler itself. When you pull the knob up it's supposed to divert the water to the shower, if it's coming out both, I'd look at that piece, inexpensive and easy to replace
Sep 13, 2010 | Moen Home
The water comes out of both the shower head and the tab simultaneously. If the knob controlling the water flow is turned to the side that control the water to shower head then about 75% of the water flows...
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
Jun 02, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Grohe Eurosmart, 3-hole Roman Tub Filler and Hand Shower w/ StarLight Chrom Logo
1,183 people viewed this question
Top Grohe Home Experts
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
