Question about Tomtom ONE GPS Receiver
Red cross across sd card
I accidently took out the sd card and now have a red cross across the sd card,i have tried resetting,any other suggestions would be appreciated
  • 74 Answers
It sounds like you need to reformat the card to get it working again but you will LOSE ALL THE DATA on it if you do that.
BE SURE before you do this. Find someone who can help you do this to make sure you reformat the right memory device.
Peter
Posted on Feb 24, 2009
When turn On can get the screen showing the GPS connected to Computer when not connected ,On Battery only, get red cross flashing
If your TomTom shows a red cross, it means the device is not able to load the software to be able to operate. Some devices have this software on a SD-card, some have it stored on an internal memory.
If there was a SD-card in your TomTom, I would suggest to put it back. If there is a empty SD-slot on your device, it could be you lost your SD-card, but some TomTom devices have an internal memory AND a SD-slot for memory extension, so if you have an empty cardslot it doesn't necessarily mean there has to be a card in it.
When you never saw a SD-card, probably some data went corrupt on the internal memory. When you have a SD-card, probably some data got corrupted on the SD-card.
To repair the software, you need to connect your GPS to your PC or Mac with a USB cable.
You also need the program TomTom HOME. You can download it for free on the TomTom website.
With TomTom HOME you can update the operating system of your device for free (map updates are nor free).
Try updating, and see if your device works again.
If this doesn't work, post it here.
May 14, 2015 | Tomtom GPS
SD card with TpmTom One
That's a basic SD compatibility issue. Can you identify the maker of the cards, please? Got backup?
Feb 10, 2008 | Tomtom 1D00.081 GPS Receiver
My tom tom one when i swith on the screen shows the sd card being removed from tom tom with a red cross across sd card.the sd card is in side .i can not past this screen or use gps how do i fix thanks
It is likely that the SD card (data) is corrupted. I'm assuming that it had previously worked properly.
Have you tried running a (fix) disk utility against your (internal disk or SD card) storage for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
This utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 24, 2013 | Tomtom One XL GPS Receiver
When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Jun 14, 2009 | Tomtom One XL GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
My tomtom one has a red cross across sd card when i turn it on
no that will not work see pullin the sd card out of the tomtom kinda pisses off the application if u have the red x error first do the soft reset if that does not work then update ur tomtom an application should pull thru as a download if not dont fret on tomtom home go to show contents on my one then delete just the application and i mean just the application then go back and hit update my one it will download and install new app and boom baby all done
Jan 20, 2009 | Tomtom ONE GPS Receiver
My Tomtom is not working
Unfortunalty , you have missing , corrupted or damaged files on your SD card. if you backed up your SD card earlier to a PC , then format and reinstall them to your TomTom SD card.
good luck
Nov 06, 2008 | Tomtom GO 300 GPS Receiver
SD card problem
The most likely cause for the RED CROSS is that some files are missing or corrupted on the SD card. This can also occur if someone has accidently dragged and dropped files on the SD card. ie. if a folder or file has been accidently dropped into a different folder. For instance you could drag and drop the maps folder into the voices folder. In this case the unit wouldn't load up if you had no maps although the maps would still be on the SD card but would be in the wrong place. We all know that files on media can be damaged or become corrupted so its always worth making a GOOD BACKUP of any sd card so that should this problem arise you can reinstall the backup.
If you have no luck with your SD card , you could try borrowing a card off someone you know and make a copy of it then activate that copy by using the original activation code together with the device code. .... good luck .
Nov 06, 2007 | Tomtom 1D00.081 GPS Receiver
Tomtom ONE GPS Receiver Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
