Question about Epson Stylus Photo 1270 InkJet Printer
High Quality printing failure
I received a broken printer, but all there was to it was a slightly dried ink cartridge and an internal error, leaving printer seemingly unresponsive. After pushing the right combination of buttons and cleaning/realigning the print head, the printer prints pretty well, but only on draft mode.
If I try to print higher quality, the printer starts printing and then completely stops, giving an error:
"A general error has occurred.
Delete the all print jobs in the EPSON Spool Manager and turn the printer off. Check for foreign objects that could be jammed inside the printer."
The two ink lights are lit, and the other two are flashing.
Does anyone have any ideas what I can do about this? I don't see anything that could be jammed. Maybe I'm not looking in the right place? Any suggestions are much appreciated.
  • 154 Answers
Hi, try putting a little 3 in 1 light oil on the bar thgat the print head runs on, the 'bale bar' as it is called can get dry and jam, only put a little oin in 6 or 7 places otherwise, you may end up with oil in the parer drive mechanism.
Posted on Mar 02, 2009
My hp envy 5530 is only printing half a picture
If it is only printing the top half then it is quite possible you are running out of ink. Try printing on only black and see if this works. When is the last time you replaced the colour cartridge?
Feb 25, 2015 | HP ENVY 5530 e-All-in-One with 2-month...
How to reset inkje even with new refilled cartridge
Regarding your recent inquiry about the Canon 240 (black) or 241 (color) ink cartridge ink alert/error condition and the inability to print to your Canon MX452 printer, to reset the cartridge ink low/empty alert message condition, depending on your printer model, we suggest you follow the documented procedures below and/or provided on Inkjet411 at the following link. http://inkjet411.com/?page_id=1765
Essentially, in most cases, all you need to do is press the 'Stop/Reset' button (triangle symbol inside of a circle) for 5-8 seconds and the ink error ("ink has run out", etc.) indicators should extinguish; two common reset procedures are provided below (please refer to both videos): http://inkjet411.com/?page_id=1765
Canon 30/31/40/41 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2709
Canon 50/51 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2719
Canon 210/210XL/211/211XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2728
Canon 240/240XL/240XXL/241/241XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2733
Canon 245/245XL/246/246XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2740
If you have already attempted the 5-8 second printer reset without success, then refer to WORST CASE SCENARIO section below.
ADDITIONAL NOTES:
NOTE 1: Providing you can still print, you will need to wait until the "ink has run out" message appears on your computer, before activating the 'Stop/Resume' button for 5-8 seconds. However, if printing is not permissible, then please keep reading....
NOTE 2: If you are able to print the internal self test print, this will demonstrate that the ink cartridge is 'at least' partially functioning. If this is the case, then we suggest you continue printing until the software prompts you to press the 'Stop/Reset' button for >5 seconds. For poor print quality performance issues (as you indicated in your inquiry), we suggest you run a nozzle/cartridge clean test from your Canon software, followed by printing our 'Ink Recovery Test' print: http://inkjet411.com/wp-content/uploads/2013/02/Test-Print_CMYK.pdf
NOTE: To rule out connectivity issues, please ensure BOTH carriage/flex cables (point where the cartridge connects to carriage inside the printer) and BOTH ink cartridge rear electrical contact surfaces are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
      WORST CASE SCENARIO - INTERNAL ELECTRICAL FAILURE OF INK CARTRIDGE:
      If, after performing the suggested 'reset' procedures above, you still have an error condition which prohibits computer/host based printing (or permit copy/scan functions), then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page: http://inkjet411.com/?page_id=1533
      If, following a reset of the printer via the 'Stop/Resume' button, printing is permitted but the 'Ink Low' indicator continues to be lit then one of the inks cartridges may be suffering from marginal internal electrical performance - a potential failure of the cartridge may eventually occur which will prevent printing.
      CAUTION: Be advised, the use of Canon compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures (due to incompatible ink formulations which may contain volatile organic compounds, or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Canon original/genuine ink cartridges is only suggested!
      Canon 30/31 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=3khyqBHMPVc
      Canon 240/241 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=HyEhCOxvdsA
      If you do need to purchase a new ink cartridge (to save on ink costs), we suggest you try a USA remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and come with a 1-year warranty.
      Alternatively, if you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (in ink compatibility or color output) with all of these models: http://inkjet411.com/?page_id=3585
      Please let us know if you have any questions regarding the technical information provided above by sending an e-mail to us directly: Inkjet411help@gmail.com
      -Thank you
Jul 20, 2014 | Canon Pixma MX452 Wlse All-In-One Printer...
When i put on black ink cartridge of HP4200 all in one printer it will turn Error and willnot print but if i remove and leave only the colored ink cartridge it will print sometmes colored sometimes black
1. Mono cartridge faulty, replace it
2. Color cartridge dried up/nozzles are blocked..Perform nozzle clean.. after cleaning also not satisfied, replace it..
** Suggestion: If you replace both cartridges at a time calibration and print quality reaches 100%..better go for replace both..
Oct 08, 2012 | HP LaserJet 4200 Printer
Photosmart B8550 color inks running low after printing only 1 or 2 4X6 prints. Also, have refilled cartridges, and black is coming out blue. I'm using a MacBook Pro OSX 8.6. I have set the print...
BETTER SOLUTION IS IF YOU TAKE MORE PHOTOS I SUGGEST YOU BUY ORGIINAL INK CARTRIDGES.THEN YOU CAN DO ONE TIME REFILLING.ITS OK.
AGAIN IF YOU TRY REFILL SAME CARTRIDGE MAY LOSS YOUR PAGE YEILD. IF U WANT USE REFILLED CARTRIDGES AGAIN BUY VIRGIN CARTRIDGE FROM REFILL STORE AND MAKE REFILL. OTHERWISE INK WILL FINISH SOON.
FOR BLACK INK U SHOULD REFILL OR BUY NEW ONE NOW. BECOS BLACK INK FINISHED ALREADY. THATS WHY YOU GETTING BLUE PRINTING....OOOOOOOOOK DEAR...
Jun 29, 2011 | HP Photosmart B8550 Photo InkJet Printer
Replaced empty black ink cartridge, wont print black ink even after cleaning and aligning the printheads
The head of your printer cartrige (black) are not detected by the printer because it was damage and need to be replace. So that no more black ink could print anyway.
May 26, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
HP C309a. Just refilled my original cartridges, but the black now won't work. I did get a message saying that the black cartridge had been reinserted, or something similar. Any ideas please. Someone said...
1. Do U use "HP Solution Center" and if yes, do u see the cartridge in "estimated ink levels" window (if U don't, try clean the chip's pins on the cartridge)? 2. The "Photo Black" is pigment ink while the "Black" is dye ink.
Apr 04, 2010 | HP Photosmart Premium C309A All-In-One...
Printing with generic cartridges
Lexmark International does not recommend the use of third party inks or inkjet cartridge refill kits. Genuine Lexmark inks and cartridges are perfectly matched to the printing system. Using genuine Lexmark ink and cartridges ensures that every document produced is of the highest possible print quality, providing long-term dependable service from your Lexmark printer.
Lexmark cannot assure the excellent print quality and reliability of its inkjet cartridges after a cartridge has been refilled. Using incompatible inks in an attempt to extend the life of a genuine Lexmark cartridge beyond its recommended usage can cause failures in several different areas of the printer. Inkjet cartridges and printer failures caused by refilling or a third party ink are not covered by your Lexmark printer Warranty, Extended Warranty or Service Agreement.
Please use genuine Lexmark cartridges for best results.
Apr 20, 2009 | Office Equipment & Supplies
Cannot overide "wrong cartridge" message when using oem cart
Apr 13, 2009 | Office Equipment & Supplies
Epson Stylus Photo 1270 InkJet Printer Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
