Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher SHU5305 stuck on 1 running for hours.
My Bosch SHU5305 would be stuck on the number 1 and run for four hours in the regular wash mode. After reading your great DIY fix it forums I figured out that the #1 on the display is a code for control module has timed out and not the one minute timer. I also learned it could be a burned solder joint on the module and that is exactly what is was. So I took it to my computer repair guy and he soldered it for me. so far its working great.
Thank you very much
  • Anonymous May 13, 2009
    I have the exact same problem. I just don't know if I can fix it myself :(
2 Suggested Answers
  • 2605 Answers
SOURCE: How do you take the
Hello Steve,
Welcome to FixYa.
If you email me at my windows live account I will send you an official B/S/H/ ( Bosch ) service manual that should explain fully & completely how to not only take it appart, but how to repair it as well.
Let me know if you want to receive this info or not either here or via email.
To provide the info it must be through email as the adobe files are too large to post here.
I`ll watch for your reply.
macmarkus :)
Posted on Sep 21, 2010
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Bosch SHU4302UC/UO6 runs three hours.
Maybe wash temperature. The machine may be trying to heat the wash water to a preset temp and it is taking an extended time to get there. Maybe a faulty temperature probe or a bad element?
I know you will ask how this is possible when you have a final temp of 120 but that sound like a drying cycle temperature to me; not a wash temp.
I would leave the thermometer in through the cycle and you will probably find it will slowly get hotter in wash cycle and finally switch after a certain temp has been obtained.
Oct 05, 2017 | Bosch Dishwashers
I have a Bosch dishwasher Model number SHU4302UC. The dishwasher takes about four hours to wash dishes. During the rinse cyle it can be running for over an hour and I will open it to look in side and find...
possibilities are that of an inefficient heating element ie..scaled up if hard water area especially. whilst the cycle is being completed then the components are working... so other than the element check the drainage for blockages (slow draining adds time) & also water pressure as low pressure adds time to the filling..
Dec 21, 2009 | Bosch Dishwashers
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
Jul 24, 2009 | Bosch SHU5316UC Dishwasher
What is the amount of time for a regular wash? Time on the plus wash?
a regular wash should take about an hour and a half. plus wash would be longer only because it heats the wash temp hotter.
wash temp is generally around 140 degrees
and your rinse is around 161 degrees.
your flow through heat assembly heats the water at 2 degrees a minute. so it can take anywhere from and hour and a half to two hours for a full cycle.
try turning your sink on hot water until you feel hot water coming out then start the dishwasher so it doesnt have to heat cold water up to those temps. it should run a little shorter.
Feb 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher cycle doesn't end
Try this link, for procedures for running self-tests on various Bosch models using the front door switches. Find your model and read and follow the procedure.
This remaining at '1' problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. See pic here of open solder joint In most cases, the heating element has not been at fault.
I got mine going again by resoldering the joint and saved ~$300 in parts & labour. If this is beyond your skill set, then replace the control board assembly, 266746, which is used on multiple Bosch models. See this page for more information if you want to try to DIY.
If this is still beyond your skill set, then call a tech & supply the Bosch model, serial number, and the results of the self-tests.
Jul 08, 2008 | Dishwashers
Bosch 24 in. SHU53 Built-in Dishwasher Logo
692 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
