Question about LG 42PX5D 42 in. Plasma HDTV
When i set the picture mode after 5 minutes it
When i set the picture mode on my LG 42 6000 after 5 minutes it resets itself, whats the problem.
    President:
  • LG Master
  • 1,779 Answers
Sounds like a software problem, may need a firmware update. Best thing to do is take it to an Authorized LG Service Center.
Posted on Feb 18, 2009
I am pressing mode button of lg ac but cooling sign is not desplayed.auto and dehumidifying is dysplayig.now how i can solve this problem.pls help.
Disconnect power to the wall control panel and to the AC unit and wait 5 minutes, then reconnect and see if it resets itself.
Aug 03, 2016 | LG Heating & Cooling
How to master reset LG tv 50PG20, and do a firmware update
To do a master reset [System Reset] you have to enter its service mode option. Electro help Check this link to get more details. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 06, 2014 | LG 42LC2D 42 in. LCD HDTV
The recorded picture is very blurred
I had the same problem on my LG rht599h dvd recorder, I had set the record mode to SP but it would switch itself to MLP mode which was very blurry, Why there is a MLP mode anyway I cannot understand because the quality is terrible. To rectify the problem go to setup and reset to factory setting and that will stop it from switching once you set to the mode of your choice.
Feb 18, 2013 | LG RHT599H 500GB HDD DVD Recorder with...
How to take off sleep mode
Sleep Mode
Setting the Sleep Mode reduces power consumption while the machine is idle.
You can choose how long the machine is idle (from 00 to 99 minutes) before it
drops into sleep mode. The timer automatically resets itself after the machine
receives a fax or PC data, or makes a copy. The default setting is 5 minutes.
1 Press Menu, 1, 8.
2 Use the Dial pad to enter the length of
time the machine is idle before it drops
into sleep mode (00 to 99 minutes), and then press Set.
3 Press Stop/Exit.
Oct 10, 2011 | Brother Office Equipment & Supplies
Picture setting reverts to Vivid
LG replied to my enquiry abd apparently the TV was in store mode. Just required a factory reset,...seems to have done the trick !
Jun 03, 2009 | LG 42PG20 42 in. Plasma HDTV
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
Lg Plasma Display settings keep switching
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
Jan 07, 2009 | LG 42LC2D 42 in. LCD HDTV
LG 32'' LCD TV aspect ratio self switching
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Nov 19, 2008 | LG 42LP1D 42 in. LCD HDTV
Picture mode changes to zoom by itself
It sounds like an eeprom issue. But you can try to reset the set. Turn the set off by the main power on the set. wait a minute or two then together push both the main power button and the standby power button. This should resett the tv. If that doesnt work you will need service as the zoom and the various modes are all controled by the eeprom. Only hold the two buttons for a second. sometimes you will hear the crts discharge while resetting.Hope this helps
Jan 03, 2008 | Pioneer SD-582HD5 58" Rear Projection...
LG 42PX5D 42 in. Plasma HDTV Logo
133 people viewed this question
Computer Repairing
Computer Repairing
