Question about Brother HL-2040 Laser Printer
Toner light stays on despite replacing toner
I replaced the toner; and go through the reset cycle ( and rocked the toner cart.) but after one sheet, the toner light still comes on and the printer stops working ( the printed sheet looks fine)
Is this a remanufactured cartridge? if so the remanufacturedr may have neglected to install, or improperly installed the Reset lever? The initial cartridges that came in the printer didn't have them. On the left side of the new cartridge (if you're holding it as if you were going to install) you should see e white lever seated in sort of a half moon slot. this lever should be toward the front of the catridge when it is new and it gets pushed back as the new cartridge is engaged, to let the printer know it is new, and reset the counter. If this is not the case you should get a replacment
Posted on Feb 18, 2009
When printing the sheet comes out half black
Sounds like the Photo-conductor is going bad. If it's a separate part in your printer, you just might want to change it out. Otherwise it might also be built into the toner cart, and you'll need to get a replacement toner cart. Not usual but, i've seen a few bad toner carts.
Hope this points you in the right direction.
Thanks!
Please Rate:)
Gary
Apr 06, 2016 | Samsung SCX 4521F All-In-One Laser Printer
Epson sx400 has just stopped printing, it only produces a plain sheet of paper. I have checked the printer queue, switched on and off but am a loss
Ensure that the printer has enough ink/toner if you haven't replaced this in a while this could be the cause (if it's ink and you haven't used it for ages the ink may have dried up) (if it's toner, take out the toner cart gentally and lightly sway it from side to side and re-insert the cart, this can let you get some more printing out of an "empty" cart)
if you have replaced the ink/toner recently try printing off a test page from the printers software or alternativly the windows printing device menu
Mar 29, 2011 | Computers & Internet
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
What is the difference between a toner and a drum on a BB4400 OKI printer?
The toner is the black powder which the printer uses to turn type and pictures into a printed piece. The drum is the device that actually fuses the image to the paper. Toner cartridges and drums have a service life. Toner cartridges will have say a 3000 sheet capacity. When it is empty you replace it. The drum will have a 10-20,000 sheet capacity. Typically the drum is three to four times more expensive to replace. Many companies will give you a credit for turning them in vs ending up in a landfill.
Good luck.
Aug 04, 2009 | Office Equipment & Supplies
The ink light stays on
You need to either reset or replace the chip on the toner cartridge. I would not recommend refilling toners carts, in particular if the machine is still under warranty.
Jun 18, 2009 | Samsung CLP 300 Laser Printer
Toner light on, will not print
These printers rely on a manual lever on the side of the cartridge to tell the printer there is a new toner cart. The lever has two arms for the 550 (low yield) and one lever for the high yield cart. It sounds like the gears were not reset on the cart. Is the cartridge brand new, or remanufactured? I can give you more info on how to reset the cartridge.....
Mar 10, 2009 | Brother HL-5250dnt Laser Printer
Toner light will not go off
Take the drum/toner out and with the front cover open press the blue 'go' button once, then put the drum/toner back in and press the button once again, then close the cover.
should reset the toner for you
Nov 10, 2008 | Brother HL-5240 Laser Printer
Hp 4600 color laser leaking yellow toner. The carts are actual Hp carts. Any ideas? Had problem with reman carts in April changed to origianl - now happened again. Any suggestions
How to fix toner (Magenta) leak in HP4600...
I have read and tried everyone methods (dc controller, replacing toner, & adjust paper sheet type) of resolving toner leak. The answer to everyone's problem, is to " check & replace the the two black alienation plates (1.5" wide by 10" long, strips are vertical position, held by 2 phillips screws)" located on the back wall after removing all 4 toner cartridges. I found that the plate had cracked and didn't allow the toner to close properly. I temporary superglued the part back and order a new kit (Q3668-67925 $19.99 + s/h). Problem solved.
Sep 24, 2008 | HP Office Equipment & Supplies
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
Brother HL-2040 Laser Printer Logo
138 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
