Question about Cook's Essentials CEM848 Handheld Blender
I just received an 8 Qt Cook's Essentials pressure cooker and the top handle has a chip out of it and the bottom part of the handle is completely broken off..Can I order these? What do I do? Thx Pat phallmon@bellsouth.net
    President:
  • 267 Answers
My parts book says no . listing : PRIVATE BRAND , CHINA CONTACT QVC, USA IMPORTERS 1-888-345-5788
Posted on Feb 20, 2009
Maual for cooks essentials soup maker
https://www.cuisinart.com/share/pdf/manuals/sbc-1000.pdf
Mar 16, 2015 | Cuisinart Blend and Cook 4-Speed Soup...
Why is my pressure cooker not running the length of time set?
You probably need to push set again or something when it appears you should be done. I have a slow cooker and they work that way. It appears to be running but you still need to push one more button or the program will stop after 15 minutes.
Sep 21, 2014 | Cuisinart CPC-600 6 Quart Electric...
Instructions for cooks profesional soup maker
Hi Derrick, I can't help you on the Instructions for the Cooks as I have been unable to find any on line. There are Instructions for another identical model made by a different company (Coopers)and the eight buttons are marked in a totally different way. I got my almost unused Professional Soup Maker discarded in a dump, minus the lid and filter sleeve. When I discovered the lid was essential as it contained a magnet to complete the circuitry, I got a small one from a toy, switched on the power and moved it over the jug handle top and the thing sprang into life! You have to use Blutack to fix the magnet to the r/H/s of the handle. I used an old pot lid belonging to my dear recently deceased wife and it happened to fit.
I have been working purely on trial and error and simply entering the name of a soup on line and some great recipes come up- however, without specific quantities to suit the machine. It still works well if you just chop up anything you have in the veg basket and put it on P2 by powering on and pressing Menu till P2 comes up. I recommend trying Mushroom. It's great ! There are others.
without the magnet you get E2 (error) on the window, meaning no lid.
I made a filter by cutting down a cutlery draining basket from Dunelm. It stops the cutter from making a slush of the veggies.
Please feel free to come back if you feel I can help after a few weeks of trying a few trials. Don't be frightened, as you can't do any harm. You will get a fright first time when the cutter goes off like a bomb for a couple of seconds! But harmless. I think this machine is good and worth a bit of experiment. I have to make all my own meals now and found the machine a great help for nourishing meals avoiding ready made packet stuff. Any questions just get back to me.
Alex MacMillan, Edinburgh, student cook!). Good luck.
Mar 07, 2014 | Cook's Essentials Soup-a-chefs Electric...
What is the phone number for Cook's Essentials
The only contact telhone number I have is 1-800-233-9054 for cunsumer service.
Apr 06, 2012 | Cook's Essentials CEM848 Handheld Blender
How do you remove the cuisinart blender handle to clean he glass beneath it?
i have a perfect answer! and own this very modle with the same issue. Plus i have done it myself.
Instructions:
*on the lower part of the hadle you will see two holes, with a small 6" school sized METAL ruler (no thicker than 3/4mm) gently insert it inbetween the two holes and push down. ((The handle has a clamp there) NOTE: you MUST start at the bottom of the handle or you will brake it!
*then while still inserted push the ruler away from the jar. this should releese the clamp that will allow you to remove the outer piece. REMEMBER your handle is plastic.
*now slowly lift upward and the side clamps will release. STOPpulling when you get to the at the top clamp.
*now you want to carefully hold your thumb down with slight pressure on the top of the handle (where you see the ingroved space that connects the hadle piece, it looks just the same as the bottom but without the holes) and lift up the handle slowly. this should release the outter part of the handle.
* now that the outside piece of the handle is off you can see the scews, unscrew with a phillips scewdriver and take handle fully off.
*Lastly the wire-like rings MUST be slipped off towards the bottom. do NOT try to prie off the wire-like ring from the little piece that is holding it together to create the ring, you will snap it.
*after you have taken off the rings, clean them with VIM (with bleach) by placing them FLAT on the sink edge to keep them from changing shape. Scrup away. Also scrub the plastic parts but DO NOT use the VIM on the outside of the plastic handle as it could scrub away the silver paint. only do this on the inside to remove the mold and grime.
NOTE: VIMis the only thing i found that will even remove rust build up. use an old toothbrush to scrub away the rust and grime. preferably dry with the vim, no need for water. water will dilute the VIM and cause it to be uneffective.
* you can take the little nub that conects the rings off by twisting them to the left or right, for cleaning, doesnt matter. I tried both ways but prefer to keep them on.
* now that you washed all parts let them DRY or you will end up with the same rust and grime issue. After the parts have dried you can now reasemble youir handle, and have peace of mind :)
* Try not to overdue the assable and reassambling of your handle, keeping in mind it is made of plastic and plastic wears easliy.
Hope that helps.
Jun 14, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
COOK'S ESSENTIALS BLENDER CESS700B GASKET
Go to: http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3694&secid=53&linkon=category&linkid=91 My Cook's Essentials is just like the Back to Basics model SE 2000. Yours may be one of the other models, click on replacement parts at he top. I hope this works out for you too.
Nov 10, 2008 | Cook's Essentials Smoothie Maker Work Top...
Cook's Essentials CEM848 Handheld Blender Logo
201 people viewed this question
Top Cook's Essentials Blenders Experts
Ross Keen
ray gallant
Tom Chichester
Are you a Cook's Essentials Blender Expert? Answer questions, earn points and help others
