Question about Xerox Office Equipment & Supplies
The paper feed does not take the paper
I have a Xerox workcenter 215. It does print when i open the cover and put the paper inside one by one but does not take from the automatic feeder. I want to open that part and clean it because I think that there is a piece of paper stuck in there.
  • 547 Answers
Open where paper goes in if no paper then it could be you need to set it for auto feed
Posted on Feb 18, 2009
How do I fix a printing problem where the error message load tray 1 keeps appearing?
You Really need to have this Machine Cleaned. there is too Much Paper dust On the sensor
Jun 06, 2015 | Xerox 6505/dn Workcenter 6505dn Color...
Laser printer prints streeks in magenta
swap the A2 and A3 drum.
Send a new color print
If streaks become blue, than you have to replace the drum in the A2 position.
Apr 11, 2013 | Xerox Office Equipment & Supplies
My Xerox Workcentre PE120i screen says [no paper] "Add paper". but the tray is full of paper. What do you suggest I do?
This is a fairly common problem with most printers. It is generally caused by something confusing the sensor that detects the paper.
1) Remove all the paper from the printer.
2) Switch off the printer and unplug from the mains for 30-45 seconds
3) Switch printer on
4) Put in paper
5) Try and print!
Most of the time this will cause the printer to "reset" itself and should print fine.
Regards,
sjstore2
Dec 20, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
I need to print standard size 10 envelopes. Where/How do I load them? WorkCentre7335
Some setup will be necessary both on the WorkCenter and in your software. I will describe these steps and leave you with a link to Xerox to check as a reference:
On the WorkCenter 7335
1) In the Bypass tray, load the std. 10 envelopes width-wise with the side to be printed down, flaps tucked in and with flaps entering the printer first. Slide the guide to just touch the edges.
2) Touch <Change Settings> on the WC 7335 screen
3) Select "Envelope" from the "Paper Type" list
4) Select "No. 10 Env" from the "Paper Size" list
5) Select "Save"
6) Select "Confirm"
In your software:
As you did not specify your software, it is important to note that whatever application you are using, the following settings must agree with the steps above:
1) Feed method = Face down, Clockwise rotation
2) Feed from = Bypass
These options may be chosen in different ways depending on your software program.
You may review these setup steps for Word here:
Xerox WC 7335 Print Size 10 Envelope
Jan 25, 2010 | Xerox WorkCentre M118 Laser Printer
Xerox PE 120i workcenter. Error says
you need to remove your paper tray.take your toner carriage out ,yurn the mc and assess
Nov 29, 2009 | Xerox PE120i Laser Printer
Xerox WorkCentre PE120i - Paper Jam 1
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox WorkCentre Pro 215 E2 Error Code
Nov 19, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
[No Paper] error
take out the paper tray and look inside. You will see a feed tire about 4 inches in, on the upper frame over where the paper stack would be. Right behind that feed tire, there should be a black hook shaped actuator that contacts the paper stack when you put the tray in. It is about 3 inches long.
Either that is knocked off or the sensor popped out of its slots.
The board could be bad, but that is very unlikely.
95 percent of the time that actuator is knocked off or the sensoe is out of place.
If you cant find the actuator, if that is the problem, you can slip a piece of tape , not scotch tape, some type of tape you cant see through, into the channel of that sensor. the only difference you would notice is you would not get an out of paper message but a jam when you ran out of paper.
Dec 19, 2007 | Xerox WorkCenter PE120i All-In-One Laser...
53 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
