Question about Yamaha HTR-5990 Receiver
Sony strdg720 problem
I have a sony strdg720 that i just got bout 3 weeks ago brand new. problem is i get a high pitched whine from all 7 speakers regardless of the volume. i trouble shot it in any possible way.even took it upstairs to a diffent plug and it still does that. anyone got a solution or the same problem? its not very loud but loud enough to be annoying at night.
  • ghostridercj Feb 19, 2009
    its the second one. the first one did the same thing and i took it back and got replaced with this one. the pitched whine is loudest when i select the multichannel soundfield. i called sony n they sed its EMI, but ive even tried it by itslef on a seperate plug. tried what u sed but its still there, just lower.
    no open computers in the area. its not the ground buzz for sure..that faraday cage sounds like a cool idea, but im thinking its the actual amp thats the culprit. ive tried the receiver by itself on a lone plug in a different room but the same result. i dont have a frame at the moment but if it persists i'll just call sony,my strdg710 upstairs is extremely quiet when idling.
  • 4,234 Answers
Try turning off any surround mode so all you have working is the 2 front speakers. If the soundgoes away, the problem is in the digital surround processing and you are hearing the results of digital noise. Since this unit is new, return it for an exchange indicating the problem. It should not be making this sound.
Dan
Posted on Feb 18, 2009
  • ABRsvcs Feb 19, 2009
    The EMI excuse sound a bit suspect to me. What else is in the area? Any opened computer systems? If the sound still happens with the surround in bypass, then there is no digital processing involved. Make sure that the ground is good on the outlet you are using. A good ground will help.
    One other thing you can try is to make your own Faraday cage. Make a small frame that is large enough to go around the entire unit. Cover the frame completely with aluminum foil with no gaps other than the front so you can get at the panel of the unit. Ground the foil to the screw of the outlet. This will create an interference free zone. If you still get the noise, tell Sony they have a problem with the unit and request a fix. This will prevent any EMI from affecting the unit.
    Let me know what happens.
    Dan
Why is there a high pitched whine coming from rear of 2003 yamaha roadstar
Hi, Anonymous I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Shifting Trans---CLUNK
7. Gears---WHINE
8. Front Forks---PLUNK
9. Rear Shocks---SQUEAK
10. Starters---CLICK
11. Solid Lifters---TICK
12. Hydraulic Lifters---TAP
13. Pistons---SLAP
14. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Re Chirp and High Pitched Whine Road Star Forum Yamaha Road Star
weird noise whine
http://www.werder.ee/Manual/XV1600.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-44_361.pdf
Jul 02, 2014 | 2002 Yamaha XV 1600 Wild Star
I have a pair of new Alesis Elevate 3 active monitors and the right one emits a faint high pitch whine. It's coming from inside the speaker, probably from the amplifier circuit. Any ideas what may cause...
Have you tried some hot glue to dampen the caps body? Plus this will reduce the internal vibrations from the speaker cones which can eventually vibrate components loose.
May 06, 2014 | Audio Players & Recorders
What is the high pitched sound coming from the speedometer?
Hi, Jeff I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
2. Belts---CHIRP
4. Chains---RATTLE
7. Gears---WHINE
13. Pistons---SLAP
1985 Honda CBX250 High pitched whining sound coming from tacho speedo...
http://www.venturerider.org/forum/showthread.php?79642-Occasional-quot-Whining-Whirring-quot-noise
Yamaha XJ700N Service Manual
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Apr 22, 2013 | 1985 Yamaha XJ 700 S Maxim
High pitch whine from belt area on 03 roadstar
2. Belts---CHIRP
4. Chains---RATTLE
7. Gears---WHINE
13. Pistons---SLAP
High pitched squeal Video included
http://www.starmotorcycles.com/assets/service/manuals/2003/lit-11626-16-44_361.pdf
Jun 05, 2012 | 2003 Yamaha Road Star Silverado
Sometimes goes ''clunk'' when coming to a stop,then makes noise like a chain being dragged over a pipe in 1st gear.Noise stops after a few minutes.Has a low pitched whine in OD,sometimes accompanied by a...
Maybe a stretched transfer case chain.
I wouldn't rule out some trans issues
Got the correct fluid in transfer or proper level
The clunk sounds like ,U-joints
Check all the mounts on everything,trans, transfer.etc
May 03, 2010 | 2001 Chevrolet Silverado 1500
High pitch whining,
Ur flyback transformer it have cold soldier or is dead.U also could have prob. with ur power ic inverter board too.
Aug 16, 2009 | Sony KV-32S45 32" TV
Sony strd720 problem
Try turning off any surround mode so all you have working is the 2 front speakers. If the soundgoes away, the problem is in the digital surround processing and you are hearing the results of digital noise. Since this unit is new, return it for an exchange indicating the problem. It should not be making this sound at all.
Dan
Feb 18, 2009 | Sony Audio Players & Recorders
Laptop gives off a high pitched screech ONLY upon start ups
Assure there a no disks in your CD/DVD drive
Make sure there is nothing blocking the fan
Feel the base of you laptop and assure it is cool
Do not block off air flow
Event Viewer: Click the Start button . In the Search box, type Event Viewer, and then, in the list of results, double-click Event Viewer.
Go to the Sytem Tab - Look for any errors that seem noteworthy
Post your results
Jan 07, 2009 | Sony VAIO VGN-NS110E/L Notebook PC
Alesis M1-Active left speaker emitts a very high pitched wine that sounds like feedback
have your built-in amp checked for trouble. there should be trouble in the output stage feedback loop. this is something to be done by a repair technician
Apr 11, 2008 | Alesis M1-Active MkII Main / Stereo...
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Yamaha HTR-5990 Receiver Logo
287 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
