Question about Smeg FMC24 850 Watts Convection / Microwave Oven
Smeg Microwave SA-971C2
Seems now everytime it is plugged in, after a few seconds, it trips the safety switch. It's not the powerpoint as it does it no matter where I plug it in. It is 10 years old and has always worked fine until this problem started last week.
  • 52 Answers
The door protection circuit needs attention, the door catches operate microswitches, but there is also a third which is a crowbar microswitch. if all three do not operate in the correct sequence then the safety switch or fuse will go.
Posted on Feb 21, 2009
Smeg microwave shorting
If it's the circuit breaker in your house or apartment that's blowing, then either you are overloading the circuit, or you have a bad breaker. Check to see what other devices might be plugged into that circuit, and move as many of them as possible to a different circuit.
Apr 23, 2016 | Smeg Microwave Ovens
Tripping GFI
proceed using the common sense. You must open the microwaves for to see what happen, the coffee produce bad contacts, and reaction from component like short, etc. However the following. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 17, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
Panasonic genius1300w cuts off after 3 seconds
see this causes and fix it. God bless you
Oct 09, 2012 | Panasonic TK-929SA Stainless Steel...
Sensor goes off inside microwave after 10 seconds
Oct 03, 2012 | GE Microwave Ovens
Set clock but time goes off
Oct 02, 2012 | Viking VMOS200 Microwave Oven
Alarm list says motor rotation and cuts off
Sep 27, 2012 | Microwave Ovens
Ive got a d90d25eslr111-b1 micro combi,i poached an egg ani ie exploded in the micro,it blew the electic and went off,if i swith it on its ok,as soon as i shut the door it fuses the electric. why plea
Sep 27, 2012 | Morphy Richards Microwave Ovens
Cant plug in microwave. Everytime i do it trips GFI outlet. Same story for all outlets in kitchen. Plug in anything else and it works fine.
Hi
It sounds there is current leakage within the oven, causing your safety switch to trip.
It would be best to have a professional check your oven.
Isaac
Jan 30, 2011 | Microwave Ovens
Microwave blows fuse
The most common suspects are the high voltage transformer and the magnetron. It's also possible you have a flaky door switch or loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Jun 07, 2007 | Roper MHE14XKB Microwave Oven
Oven not coming on but timer and lights working
The door switches are almost certainly the culprit - probably the upper one. It may also be a loose mount, or even a loose spring in the hook-like devices on the door which activate the switches. There is a center monitor switch whose purpose is to blow open the fuse if the door is open and the upper or lower switch gets activated. That's why the fuse blew when the screwdriver was introduced - you activated the door switch while the monitor switch was on. I've attached a generic picture which gives you the idea. More importantly, at my Web site, I have critical safety information, disassembly tips, and infomration on checking and replacing door switches. You can find these via my link at FixYa here: http://tinyurl.com/yzjozk
Feb 03, 2007 | Smeg FME24X Microwave Oven
Smeg FMC24 850 Watts Convection / Microwave Oven Logo
211 people viewed this question
Top Smeg Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Smeg Microwave Oven Expert? Answer questions, earn points and help others
