Question about Acer AL1916W 19" LCD Monitor
Acer AL1916W has black screen
My monitor has been working fine and i shut my computer down and when it rebooted the power light would come on but the screen is black. I changed both cords out and it still isnt working. If you tilt the screen and put a glare on it then you can see a picture in the background. I took it apart looking for a bulb or fuse and was scared to go to deep. Is there a bulb or fuse that could have went bad? And if so, how do i get to it. lol
  • mobbsy69ers Feb 22, 2009
    hey can you show use were n how to find out if they are brocken or not working my monitor gets power there is an orange light on for a a bit but they it gos out you have to wait for a bit with the power disconected then you can plug it bk in n the lights bk up it wqorked the otherday but now it just stoped  can you help me let us know i have an email mobbsy69_dags@hotmail.com
  • susiet1977 Feb 23, 2009
    I have already taken it apart and didnt see anything broken or anything that looked like it needs replacing. But i also couldnt get all the way in. There was a cover over alot of the parts and I couldnt get it off because the monitor plug is hooked to it. It let me unscrew the power plug but not the monitor plug. This really sux because this monitor is only 1yr. old and has a 3yr. warranty but i bought it new still in unopened box at the pawn shop so i didnt register it :( Guess I learned from that mistake.
    President:
  • 2,992 Answers
The backlight in your monitor isn't coming on, so all you have is that faint image you see.
This trouble is frequently because of capacitors in the monitor which fail. Often these parts (cylinder shaped, usually a couple of inches tall and an inch or so in diameter) have visible problems such as tops that have bulged or split, or brown leakage at the bottom on the circuit board. If you're adventurous, you can take the back off the monitor and check.
If you find any capacitors that look questionable, you can get replacements at Radio Shack or from online parts sellers. Capacitors have markings on them for their value in microfarads (abbreviated as mF or uF), a voltage rating, and a polarity. Some caps have the positive terminal marked and some the negative. Just note which goes where on the circuit board. Get replacements that have the same capacitance value, but a slightly higher voltage rating. They will be a little larger physically but should still fit, and under-rating is what usually causes the failure in the first place. Observe the polarity when installing the new parts.
This all sounds a little scary perhaps, but it's really not a difficult repair. If you're not comfortable with the idea of trying it yourself and you don't know any technically-inclined types who are willing, a TV or stereo service shop could do it. But with labor and their markup on parts, you might spend over half the cost of a new monitor.
Posted on Feb 22, 2009
Hello My acer 1916W LCD Monitor Screen will not light up after turning my desk top Computer on.. Although the start light lights up okay My Screen stays Black. It only lasted over 6 months I am now using a...
you need to reset the bios in the computer take the littel battry out inside with the power of then wait a min or two re insert boot and c if that works
Apr 05, 2011 | Acer AL1916W 19" LCD Monitor
Problem with the Acer AL1916W 19" LCD Monitor. My monitor was working fine this afternoon, and now when I turn it on the green power light is on but the screen stays black. can this be fxed or do I...
either your power supply has gave out on the monitor, or, and this is more likely, a capacitor has burnt out. Capacitors are required for a lcd, plasma, or dlp screen to energize itself. a charge is built up in those capacitors, and a static pulse is sent into the screen grid energizing it. If your monitor is still under warranty, take it to your local Best Buy, as they are a certified Acer Technical service center. If it's not, you can still take it to Best Buy, but it may be cheaper to replace it.
Dec 14, 2010 | Acer AL1916W 19" LCD Monitor
Whats up with my monitor?
You have a failure in the backlight power supply. We have an article posted on our web site explaining how to repair this problem: http://www.ccl-la.com/blog/index.php/westinghouse-l1975nw-repair/ The Acer AL1916W uses the same power board as the Westinghouse L1975NW monitor. If you don't want to do the repair yourself we do offfer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | Acer AL1916W 19" LCD Monitor
Black screen. Power light is on. Everything is plugged in properly. Rebooted several times. BLACK screen. Not even a flicker of light. HELP!
Have you tried reseating the cables? if not try it first, then if it doesn't work you'll notice that after you unplug the cable that's connecting the lcd from where it's plugged in , (make sure the lcd is on) if you see the colors that means the lcd is working properly if not then there is something wrong with the monitor, but if the colors came up the lcd is working fine,. Try to check where you plug it in.
Feb 12, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
BLACK MONITOR...INPUT NOT SUPPORTED
This is the resolution problem. Pls reduce the resolution . Right click any where on the desktop and click on properties there. a popup appears just choose Setting there . there you will find the option of Screen Resolution .Just Slide the pointer toward less litlle till your problem resolve.
Sep 04, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
Acer Al 1916 W mind of it'e own
you need a new power inverter, better yet a new monitor. I have the same monitor as my secondary.
Jul 21, 2008 | Acer AL1916W 19" LCD Monitor
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" problem
Try missing around with brightness and other monitor options from the on-device button controls .. Hope this may solve your problem
May 24, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
366 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
