Question about Crimestopper EZ-95FM EzeeStart 2-Way FM/FM Remote Start System w/5-Button R
Will start but won't stay running
It will start and run for about 1 and a half seconds shut off then start again run for 1 and a half seconds and keep doing that till i hit the button again
  • cbb7177 Feb 22, 2009
    2005 gmc envoy
  • james kappers
    james kappers May 11, 2010
    what type of vehicle is this in??
  • 95 Answers
Sounds like your gm bypass kit lost power at one point in time. Have you disconnected the battery recently. If so you have to look under your dash for a little box, and let me know the exact model and i can walk you through the steps in reprogramming it
Posted on Feb 23, 2009
Why when my wifes sled overheated @ idle, will only stay running 30 seconds,keeps shutting down,will keep starting up and the that process starts again, 30 seconds,shuts down
first of all you need to know the year make and model of the vehicle you're talking about and exactly what is the real problem is it overheating I will not stay running
Mar 06, 2015 | Cars & Trucks
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
My 1998 dodge caravan won't stay running. starts up but shuts down instantantly or when i take my foot off the gas pedal,
ok i have a 1998 durango with the 5.2L 318 engine. had trouble with a bad cell in my battery. I went out bought an optima red top battery for it 800cca. put it in and had same trouble. No start without putting foot on gas. wouldn't stay running without holding foot on gas. CPU has to relearn it's programming once you unplug it for long periods of time. mine was without power for about 2-3 weeks till i got new battery. Start with this.. first check under air filter make sure a squirrel hasn't made a mess under your air filter and it's clogging the air intake. Then pull off the lid to your injector cover ( the screw down lid coming from the air box ( with air filter in it) to "carb") make sure all your cables move freely. put that all back together and close hood. Start truck with foot slightly on gas pedal to get started. keep it at about 1k to 1500 rpm for about 1-2 minutes. Rev motor to about 2500rpm and let it die out if it will. Get out lock doors with key fob if you have it. if not make sure to lock doors. ( trust me it worked for me) let sit for 5 minutes. come back out and unlock door and relock door 3 times with fob ( if you have it ) or key if you don't have a fob. Then unlock it with the key and enter vehicle. Start truck as before and keep it around 1k to 1500 rpm again for about 30 seconds rev it up and should keep running. Mine did. I think the iac was stuck from sitting and has now since loosened up.
Good luck hope ti works for you.
Jun 05, 2012 | 1998 Dodge Caravan
It will crank but won't stay running
installed new fuel pump and filter in 97 cavalier 2.2 the car will run for a couple seconds and shut off if you spary it with starting fluid it will stay running
Apr 13, 2012 | 2003 Dodge Durango
Starts then dies & won't restart
check fuel pressure, should be 40 psi.
try 2 things
spray starting fluid in air intake to see if it will stay running. It's fue then.
Try turning key to on nd wait 5 seconds for system to build pressure and pump to shut off. Turn key off, wait for relay clcik noise or 10 seconds. then turn key to ON again and wait 5 seconds to build pressure again. Then start engine. If it starts better, you have a bad check valve in the fuel pump or a bad pressure regulator on the fuel rail (unlikely).
report back
Aug 22, 2011 | 2005 Ford Expedition
Car will on stay running for a few seconds before shutting off
It could be that your fuel filter could be clogged. You can check this by doing a fuel pressure test. After it dies, all the sediment drops off the filter so when you start it back up it does run for a small amount of time but then gets clogged up again after you start it again because it picks up the sediment again. You might also want to check your ignition control module. But my guess it's something to do withing your fuel system somewhere
Jul 16, 2009 | 2001 Mitsubishi Eclipse Spyder
Crimestopper EZ-95FM EzeeStart 2-Way FM/FM Remote Start System w/5-Button R Logo
361 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
