Question about Viking VGSC306-4B Gas Kitchen Range
Gas oven part of range does not always ignite, or when it does it may take 20 minutes to do so
  • 59 Answers
Is the unit a self clean unit?
If not you may have defective igniters in the oven
Posted on Mar 05, 2009
The oven igniter stays on and won't shut off what part do I need to repair this ? 20 " gas unit
When the oven is ON, the igniter should stay on.
If the oven is OFF and igniter stays on check the sensor assembly and or flame sensor for continuity.
Jan 04, 2015 | Danby 20"" 4-Burner Gas Range with Oven...
How to operate cggf3042kfg oven
This gas unit requires the burners to be ignited by holding the knob to ignite on the control panel until the flames arise. Then you can adjust the flames to higher, or lower, heights. Also, the oven should be a simple turn to the temperature wanted and wait approximately 20-30 minutes for a preheat to occur. If this does not happen you are possibly not receiving enough gas to the unit or you have an ignitor concern.
Dec 20, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Familiar F3-1 error on Jennair #JGS8850ADS. Changed Control Panel, igniter, Sensor, thought problem was solved. After 1 week F3-1 error came back after oven is on for about 20 minutes and shuts the...
F3
or
F4
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 30, 2010 | Jenn-Air JGS8750 Gas Kitchen Range
20" gas stove: has pilot light in oven, oven lights but then after several minutes will turn off. do not smell gas after it turns itself off. Using 3/8" gas line. Please advise as to potential problems...
The oven igniter should stay on constantly as long as oven control is calling for heat and not fade off. If the igniter is too weak and not pulling enough current it may not open the gas valve correctly and gas will be let out of the gas valve and not igniter.
The likely failure is a weak oven glow bar igniter. I recommend calling a service technician to diagnose and repair your range.
Hope this helps .
Apr 21, 2010 | Microwave Ovens
Ka gas range the glow bar comes on but it takes sometimes 15 to 20 min before gas is supplied to burner in oven and finaly ignites
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 22, 2010 | KitchenAid KGST307 Gas Kitchen Range
Oven slow to ignite and come to temperature.
Change the igniter.
As they age, they often times will no longer draw enough amperage to allow the gas safety valve to open. Increasing the line voltage would help, but that's a little impractical.
Jul 18, 2009 | Kitchen Ranges
Gas does not always ignite
The igniter is not properly.Every time you go to light the stove you should hear a clicking sound.If you only hear it sometimes suspect the igniter..
Mar 31, 2009 | GE Kitchen Ranges
Oven not always working
MOre than likely your igniter is getting weak. If it doesnt pull enough amperage. it shouldnt let gas into the oven. If it is letting in gas and not igniting, I would suggest a new igniter and a new safety valve. Hope this helps!
Nov 22, 2006 | Tappan TGF320 Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
147 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
