Question about RIM BlackBerry Storm 9530 Smartphone
BlackBerry Storm 9530 will not ring
My Blackberry storm will not ring. It will vibrate but the ringer will not play out loud. I have tried adjusting the volume and turning off vibrate but this doesn't help. When I tried to play my ringtones through my media file it says error playing file not supported. Any ideas whats up or how to fix it?
  • 23 more comments
  • Anonymous Feb 23, 2009
    My blackberry storm rings sometimes. It has not rang in the last 4 days. It will vibrate if I have it set to vibrate...sometimes. The only time I know I've missed a call or have a msg is by looking at my phone to see the little red light blinking. I have adjusted the volume, and the ringtones several times - no luck.
  • Anonymous Mar 04, 2009
    My blackberry storm just vibrates and doesnt ring outoud. i have tried to turn the vibrate off but then the only thing that notifies me is the red blinking light.
  • Anonymous Mar 08, 2009
    same as other users...
    it won't ring, only vibrates
  • Anonymous Mar 09, 2009
    will not ring
    I had the same problem with it would not ring.
    Turned out when I turned the volume up on the side button, it did ring again.
    Good luck to everyone.
  • Anonymous Mar 13, 2009
    i have the same problem my storm will not ring either? i have tried everything and just dont know what to do. please help
  • SierraBlue Mar 14, 2009
    I have the same problem, it will vibrate once and will not play the ringtone. Very frustrating!! I've been trying all sorts of things.....shouldn't be this hard. Pleaset post if you find a solution.
  • Anonymous Mar 15, 2009
    someone fix this i have the same problemmmmmmmmmm
  • scotsgal Mar 16, 2009
    I had the same problem! My husband uninstalled the disc that came with my phone and reinstalled. He then reconfigured the phone and it works!
  • Anonymous Mar 17, 2009
    sometimes it rings some tomes it dont
  • Anonymous Mar 19, 2009
    My storm won't ring either. I thought it might be because I installed a new theme but I changed it back to the original theme and it's still not ringing. It also won't alert me when I receive e-mails and texts. I am so pissed!
  • Anonymous Mar 20, 2009
    Damn texts only ring sometimes. Usually it will only vibrate, but other times it wont even.. I have to check my phone every 10 minutes to make sure I didn't miss anything! SO ANNOYING
  • Tuzy75 Mar 21, 2009
    i have the same problem as well..... my phone will only vibrate when receiving texts and phone calls...but is set up for loud ringer? bloody annoying is right....having to check every five minutes to see if you missed a call.... i also have this icon on my phone "o_o" right at the top of the screen in the middle. have no idea what it means! it kinda looks like that but the underscore is connected to the o's.
  • Anonymous Mar 22, 2009
    My Blackberry storm will not ring. It will vibrate but the ringer willnot play out loud. I have tried adjusting the volume and turning offvibrate but this doesn't help. When I tried to play my ringtonesthrough my media file it says error playing file not supported. Anyideas whats up or how to fix it?
  • Anonymous Mar 24, 2009
    my numbers in phonebook wont ring but every other number will
    The "o_o" means u have a voice mail.
  • biehlkm Mar 29, 2009
    I had the same problem. My camera wouldn't work, my vidoes wouldn't play and I was getting really upset. I followed the advice on here and removed my battery and rebooted. I am now back to normal. Get rid of Slacker!
  • Anonymous Apr 04, 2009
    hate this phone
  • Tom Ditzel
    Tom Ditzel Apr 13, 2009
    I had the same problem and removing the battery resolved it. Just don't know what caused it and how often to expect the problem.
  • mykngna Apr 26, 2009
    Volume set to loud, but no ringer sound.
  • calidawl4 May 09, 2009
    i have the same problem. my phone wont ring or vibrate tho. the caller name and number pops up . . . but i only know that if im looking directly at my damn phone. its so frustrating. my bf has the same phone and his works fine. iv only had my phone 3 days and it does this!!! i cant hear ringtones and it wont play a noise for the text message either... i hate this.
  • Anonymous May 13, 2009
    Sometimes my blackberry will alert me when i have a text. Other times I have to look at the phone itself to see if the light is flashing to let me know. Anyone know how to fix this? I also just got my phone 2 days ago and look at the problems
  • vanessa_t18 May 16, 2009
    How do i type underscore on my blackberry?? i can't find it anywhere on the keyboard,symbols etc....
  • Anonymous May 20, 2009
    My blackberry storm will not ring... how do I turn the ringer back on?
  • writewlsonba Mar 18, 2011
    how can i turn on the ringer for my unlocked blackberry storm 9530. music works in the headphones and plays low without them but it will not ring????
It seems like the problems starts after using an audio streaming app (Slacker)It also seems to correct after a reset(battery out and back in).
Posted on Mar 27, 2009
I have a blackberry storm 9530 that will play music in the headphones but will not ring. how can i fix this and how do i get a blackberry acct so i can go online. this phone is unlocked and used on GSM through at&t.
Posted on Mar 18, 2011
Since yesterday my 8900 stopped ringing and clock alarm does not work anymore.
I have done the following:
1. Profiles. Reviewed my Normal(Active) profile under the Profiles menu tab Advanced. Tried several options on the Phone settings, including Out of Holster: Tone, Vibrate Tone, changed the Ring Tone, changed the Volume. Made sure Mute, None, or Do Not Disturb options were NOT selected. Nothing.
2. Chose a different profile, such as Loud. Nothing.
3. Turned the phone off, pulled the battery out and reinserted. Nothing.
4. Turned the phone on, pulled the battery out and reinserted. Nothing.
I just tried to play a music but it failed untill I pressed Menu and selected Activate Handset instead of Speakerphone and the music start to play.
Someone please help
Posted on Sep 08, 2010
I have blackberry storm 9530, i need mep code i one help me please
There are two methods for unlocking Blackberry storm 9530 by MEP number and by IMEI#.
The simplest method for unlocking by IMEI#.
You can find your Blackberry storm 9530
IMEI number by follow one of these steps.
1.By Pressing *#06# into the phone.
2.On your Blackberry cell phone, go to Options-->Status.
3.put the battery out,there should be a white sticker it will show your Blackberry IMEI #.
This Blackberry Unlocking codes provider provides unlock code for Blackberry storm 9530.
Hope this helps.
Jun 28, 2010 | RIM BlackBerry Storm 9530 Smartphone
Blackberry storm will vibrate but won't ring. ive tried takin the battery out and volume control still only vibrates.
Sounds like the phone is in the "vibrate mode"- try taking it out of vibrate by changing your sound profile to "normal". If that doesn't work, take it to your local store; it may be more of a phone issue.
Jan 30, 2010 | RIM BlackBerry Storm 9530 Smartphone
How do I unlock my blackberry storm (9530) without an unlock code?
Impossible, you only can unlock blackberry storm 9530 network with a blackberry unlock code. Remember my friend don't think to try untrusted code since if you put many wrong unlock code too many times, your phone will be hardlocked.
Dec 26, 2009 | RIM BlackBerry Storm 9530 Smartphone
Got a new Blackberry Storm and my ringer won't ring
Check either your profile or under "Options" -> "Sounds and Ringer Tones" and see if your volume is set to "Silent". Change volume to something other than "Silent" and see if your ringer works then.
Oct 23, 2009 | RIM BlackBerry Storm 9530 Smartphone
I need an unlocking code for Blackberry Storm
You can get the unlock code for the blackberry storm from the site http://www.unlocking4u.com/
Oct 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do I get the ringer to ring more then one time
Click on Profiles-select advanced-select the type of profile-select volume adjust according to your wish(Low,Medium,High or Escalating and save,After saving do hard reboot.
Jul 16, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
9,350 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
