Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer is leaking even when water in waher but washer off
Whirlpool washer lsq7533jq1
Was wondering how do you get the panel off so I can check the drain hose. inside the washer.
    President:
  • Whirlpool Master
  • 2,651 Answers
Check out you tube search whirpool washer repair, easy to see how to remoe the panel, most likely a bad pump is cause of leak. will be quite evident!! yo can even just tip unit back the underneath is open
Posted on Feb 21, 2009
Waher leaks water on floor
Where is it leaking from? Back or bottom. Hose might not be connected right on back if it's from the bottom, check hose that connects from bottom of basin to pump. May have come off and needs to be put back on and tightened back up.
Feb 22, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Code F 33 on whirlpool duet waher. Sevice guy
i think that has to do with not filling .. does water enter machine. is it filling slow?
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No water goig in
Make sure your supply is open. Try rotating the timer clockwise 180 degrees and try again. It could also be a bad water valve solenoid. Make sure power supply is good.
Jul 01, 2009 | Whirlpool WVP9000SB Front Load Stacked...
Whirlpool Duet washer leaking during clean washer cycle
the highest water fill cycle for your waher is the clean cycle.it will fill up with 2x the normal amount of water in this cycle than any other.look for a cut or wrinkle in your door boot(grey rubber outer ring that seals between door and boot)if you find one,only fix would be to replace door boot.also clean inner door glass that comes in contact with door boot ring,any hard water build up or sediment(dog,cat or human hair)will break the seal and allow it to leak.good luck
Sep 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking from the front
take a butter knife and release the two clips on the top of the front panel (look in the seem between the top and front panel and push the butter knife directly into the clips), this will release the front panel from the machine. then you can see where the water is coming from.
May 14, 2008 | GE WHRE5260E Top Load Washer
Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
Feb 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool duet washer leaking from bottom back..
sounds like you need to check your back drain could be the drain is clogged.Fill with water and see if it comes from the drain
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
How to get the back off a waher
The back is resting on some slots, try lifting the plate out of these slots.
Jun 28, 2007 | Whirlpool GSW9800PW Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
146 people viewed this question
Dan Webster
Dan Webster
Sal De
