Question about Toshiba Satellite M105-S3004 Notebook
No LCD Display, No External Monitor display
I have a Toshiba M105. No LCD display and no external monitor display. Just recently replaced the motherboard. Still no display. Ran through the Fn + F5 procedure. Checked all video connections. Checked the on/off magnetic display switch. Still no display on LCD or externally. At my wits end
    Sniper:
  • 65 Answers
If you just replaced the systemboard, the video chip is not likely to be the problem. I would say to check the cable connections and the actual lcd, but you said that the external monitor is not working either and that is not dependent upon the cable or lcd. I would say that your systemboard is probably DOA, but just to be sure do you have another laptop to test it on?
Posted on Mar 21, 2009
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
Toshiba m35x starts /stops intermittently with no power to display monitor
By whom Kathleen? You?
I ask because there are two ways to answer this;
1) You performed the procedure, and less for me to post.
2) You did not perform the procedure, and I need to explain from the beginning; using a diagnostic flowchart, pictorial guidance, and guidance from me.
While I wait for your reply, suggest perform this simple test first;
Laptop OFF, monitor OFF, attach an external monitor;
1) VGA monitor to RGB (VGA) port on left side of laptop.
Can use a CRT type of monitor (Looks like a small TV), or flat LCD screen monitor if it has a VGA cable.
http://en.wikipedia.org/wiki/VGA_Connector
OR;
2) S-Video port on left side of laptop for TV, or external video display device
http://en.wikipedia.org/wiki/S-Video
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external monitor. (Display device)
If not there are 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external monitor
3) External monitor ONLY
Press, and hold the Fn key down, and at the SAME time tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap once more on the F5 key.
Display on external monitor means there is a problem with;
A) Video Cable
B) screen Inverter
C) LCD screen
Which means if computer display was working correctly before;
1) Whoever repaired it could have used the external display option, and it needs to be set back to internal
2) The Video Cable connections are not tight, not correct.
Loose at motherboard, screen Inverter, or LCD screen.
3) Anti-Static Procedures were NOT followed, and laptop is now an expensive paperweight.
Post back in a Comment.
Regards,
joecoolvette
Apr 05, 2013 | Toshiba Computers & Internet
I would like to boot a toshiba satellite m105-s30401 with an external monitor as the laptop screen is busted and i would like to use an external monitor until i get a replacement screen, how do i get
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Mar 03, 2013 | Toshiba Satellite M105-S3041Notebook
Can i just remove the monitor assembly toshiba laptop p5085d-s8935 and just use a n external monitor
You could do that. Here is an excellent guide to replacing that model laptop's lcd which will show you basically how to remove it as well.
http://www.laptopinventory.com/LaptopInventory.php/Toshiba/Satellite/P505D-S8935/LCD
Dec 07, 2012 | Toshiba Computers & Internet
How to connect an external monitor when your screen stay whiteMy screen stop working and i don`t see to configure external display!
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 05, 2012 | ASUS M51SN-A1 LAPTOP LCD SCREEN 15.4" WXGA...
Toshiba satellite monitor is scrambled, how to fix?
Check to see if the problem is the screen Inverter, or the graphics chipset, or the LCD screen.
Use an external monitor as a test.
If the screen of the external monitor shows a scrambled display you have a problem with the graphics chipset.
If the screen of the external monitor does Not show a scrambled display, you have a problem with the screen Inverter, or the LCD screen.
90 PERCENT of the time the fault is the screen Inverter.
External Monitor;
1) You can use a CRT monitor, (Looks like a small TV), as a VGA monitor,
Or
2) You can use a flat LCD screen monitor that has a VGA cable.
A) Laptop OFF, and monitor OFF, attach the VGA cable from the External monitor, to the VGA port on the Toshiba Satellite A205 series Notebook PC.
This is an example of a VGA cable, and it's connector, and a VGA connector on the laptop,
http://en.wikipedia.org/wiki/VGA_connector
B) Turn the monitor on. If it is a CRT style let it 'warm up'.
Turn the laptop on.
C) The display is supposed to automatically show up on the external monitor.
If it does not, press, and hold down on the Fn key, and also press the F5 key.
Still no?
Holding the Fn key down, tap the F5 key again.
Display good on external monitor? Problem lies with the screen Inverter, or the LCD screen.
Either OR.
Primer:
An LCD screen does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
An Inverter (screen Inverter) is used to convert the electricity provided by the laptop, for the LCD screen, and Backlight.
As previously stated, 90 PERCENT of the time the fault is the Inverter.
Laptop open looking at the display assembly, the plastic thin frame in front of the LCD screen, and surrounds the LCD screen, is the Display Bezel. (Resembles a picture frame)
The Display Bezel is removed to access the screen Inverter.
The Inverter is right behind the Display Bezel, and located at the bottom area of the LCD screen.
The Display Assembly has to be removed from the laptop, to remove the Display Bezel.
Toshiba's term for the Display Bezel is Display Mask.
The Toshiba Satellite A205-S5804 Notebook PC is one of the Satellite A205 series of Notebook PC's.
This is a link to a free Service Manual for a the Satellite A205 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down to the second Satellite heading. The one that begins with Satellite A10.
Scroll across, and click on A200.
After you click on A200 it may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
Go to Page 146.
4.10 Display Assembly
Page 151 shows how to remove the Display Mask.
4.11 Display Mask
Page 153 deals with the screen Inverter.
4.12 FL Inverter Board
Takes a really sensitive (Read fairly expensive) multimeter to test an Inverter.
Due to the low price, and ease of replacing, the screen Inverter is replaced to test whether the old one is bad.
Example of a screen Inverter (FL Inverter Board) for a Satellite A205-S5804 Notebook PC,
http://www.batterysupport.com/toshiba-satellite-a205-s5804-inverter-p-216526.html
Compare to the price of a replacement LCD screen,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A205-S5804/
To summarize so far;
1) Display shows good on external monitor. Replace screen Inverter. Still the same problem? Replace the LCD screen.
2) Display on external monitor is scrambled also?
Fault lies with the graphics chipset.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The graphics chipset is a GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The GPU for a Toshiba Satellite A205-S5804 Notebook PC (Part Number PSAF3U-0NR00V), is an Intel (Mobile) GL960 Express,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipsets
It is soldered directly to the motherboard, therefore it is Integrated Graphics.
{Integrated Graphics is also known as OnBoard graphics.
ON the motherBOARD.
The GPU is soldered to the motherboard.
In comparison if the GPU were soldered to a removable adapter card, it would be a graphics card, and Not integrated graphics }
This means if the graphics chipset is found to be bad, motherboard replacement is the solution.
{ Disassembly guide,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm }
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 05, 2011 | Toshiba Satellite A205-S5804 Notebook
Satellite M105 S322 Display very Dim. The PC works fine with external monitor but the LCD display is dim and cannot see anything on the screen
You have lost your backlight which is a thin long bulb built into the bottom of the screen itself. You have the option of getting the backlight by itself and rebuilding the screen or buying a new screen assembly and changing that out. Below is the service guide to change the screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M105/take-apart-notebook-1.htm
Below is a general guide for display problems....
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Oct 27, 2009 | Computers & Internet
No Display....Why?
Try connecting an external monitor to the vga port if you get video on it then the lcd is bad on your laptop if nothing happens then its probably motherboard issues...
Good Luck
Aug 16, 2008 | Toshiba Satellite M105-S3004 Notebook
When I turn on the Toshiba Satellite A215-S7447 laptop, the monitor part of it doesn't turn on with the rest of the system.
Plug in an external monitor. use the <FN><F5> keys to toggle between the internal lcd and the external monitor. If the display external works and the lcd doesn't, most likely a bad inverter board.
My toshiba m105 it wasn't the inverter, it was the lcd itself, the TAB welds were no good but the lcd still worked it just had a 3" vertical blacked out area on the lcd.
Jun 11, 2008 | Toshiba Computers & Internet
Laptop LCD won't display
Bad Video.... It is replaceable if you have dedicated Video,
Need to replace the motherboard if you have onboard (integrated)video..
Jun 07, 2008 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite M105-S3004 Notebook Logo
239 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
