Question about Brother IntelliFax-2820 Laser Fax
Low toner msg stay on
After replacing the toner cardridge the low toner msg still stay on.
  • 215 Answers
Open front cover, press "options" button & press "start" then enter "1" then "0". when display shows accepted, close cover.
hth,
razors
Posted on Feb 19, 2009
MAINTANANCE INDICATOR ON
Might be empty paper tray or empty cardridge. If you are talking about laser printer; you might get maintenance warning if you refilled your toner wrong. For this case; empty toner and refill it with enough ink. (too much ink prevents toner shaft to move and causes error)
Nov 21, 2014 | Office Equipment & Supplies
Resetter of samsung Ml3470 laser printer resetter
Try this...
1 Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the scroll buttons until Maintenance appears and press OK.
3 Press the scroll buttons until CLR Empty MSG. appears and press
OK.
4 Select On and press OK.
5 Now the Toner Low Replace Toner message does not appear but
the Replace Toner message will remain for reminding you that the
new cartridge needs to be installed for quality.
The User Manual (ver. 6.00) is available at...http://www.samsung.com/us/support/owners/product/ML-3471ND/XAA
Jun 08, 2014 | Samsung ML-3470 Series
Printer not printing, it said black toner was low...put new one in.....red and blue light staying on
I hope you renew the cartridges with original samsung product, you can try to remove the cardridge aggain then slide them in and bring the two clips on each site up. now disconnect the usb cable from the printer and switch of the power of the printer for about 3 minutes, now swich the power back on and connect the printer with your computer meanwhile the computer is ready with booting, now tyr it, if it is still the same problem deinstall the samsung drivers from your computer and reboot it after they are removed then install them new from your samsung CD.
Apr 25, 2011 | Samsung CLP 315 Laser Printer
All toner cardridges are at least 1/2 full but
in the printer menu, scroll to Special Pages and print a Config page, Menu Map and also the Test Pages. If these appear to print colour properly the problem may be in the driver. Check the quality tab in the preferences is not set to B/W. If the problem still appears to be with the printer after printing the internal pages then recheck after restarting the printer.
Dec 29, 2009 | Konica Minolta magicolor 5430 DL Laser...
Received a TONER LOW msg Replced toner per directions, now I have TONER ERROR! HELP!!!!!!!
Remove toner and then re-install it.
If the toner is not made by Brother, you may not get it to work for you. If this does not fix the problem, send it back for a replacement.
Oct 16, 2009 | Brother MFC-8460N All-In-One Printer
"Toner Low" keeps showing
Hi Meridy!
There could be a few reasons for the Toner Low msg you're getting.
  1. The toner wasn't evenly distributed when the cartridge was changed (shake gently from side to side before installing)
  2. The cartridge wasn't properly installed (ensure that the lock lever "clicked" into place
  3. The corona wire wasn't cleaned when changing the cartridge or the the blue tab wasn't put back in place (this is less likely the issue but still a possibility)
  4. The new toner cartridge was old and is now defective
I hope this helps with your problem. All the best!
Greg
Jun 17, 2009 | Brother IntelliFax-2820 Laser Fax
I already replace a new toner but there an error msg AP
Hi
The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up.
The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
Jun 15, 2009 | Kyocera Office Equipment & Supplies
Alarm light flashes; lcd toner low. But it's not!
How do you know toner is not low? You can't get rid of the message. The toner sensor is within the printer, and if it says 'toner is low', then it either "is" or the sensor is defective.
Apr 25, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Cartridge error msg
You have a bad toner cartridge or a poorly remanufactured toner cartridge. This condition called "false toner low".
Mar 12, 2009 | Office Equipment & Supplies
What does the following error msg mean on a Oki B6300 printer
la verdad nc a lo qt refieres o mejor dicho no t entendi la pregunta......
Jun 13, 2008 | OKI B6300n Printer
Brother IntelliFax-2820 Laser Fax Logo
329 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
