Question about Quantum Fitness Q 3.0 Light Commercial Treadmill
TReadmill shaking while running.
I have a quantum 3.0 and it shakes bad when i am running at 4.5 and above.. i am 230 pounds which is below the user weight... it sits on indoor outdoor carpet that has no padding...help i dont want to get rid of it... it cost me a pretty penny and i am sure it was worth ever penny. I am looking for a simple inexpensive solution
  • Anonymous Apr 17, 2009
    I had the same problem at a local gym. At only 180 lbs I shook up whatever treadmill I ran on enough that gym management asked me not to use the treadmills. I have seen others use the same treadmills without the same problem. I can only conclude that it must be my technique (and possibly that could be your problem), but have no idea how to fix that...
2001 Toyota Corolla shaking
4 cylinder cars shake more than v6's-my ford focus shakes so bad the mirrors wiggle- cheers Denny
Nov 19, 2013 | Toyota Corolla Cars & Trucks
I have a noise coming from the left side front wheel are. It is a rattle - took it to a local Toyota dealership who said it was the steering RAC well that was a $1000 mistake because the noise did not...
1) Take car to non dealer shops willing to give FREE opinion
2) Not likely you have a shock in Driver Front wheel, more likely a strut. Not likely strut needs to be replaced, but strut has a STRUT MOUNT (3 bolts of which can be seen when opening your hood) below this it is connected to STRUT BEARING which below it connects to UPPER SEAT OF STRUT or SPRING INSULATOR, that if loose will rattle. Usually, shops will not tighten, because to tighten is same labor as replace the parts. (Since you already dropped $1000 on ToyotaDealer, ask them to tighten FOR FREE since rattle is still there.)
3) There is a part called a "link," connects strut to stablizer bar, that if bushings are bad will rattle.
4) If stabilizer bar bushing(s) bad, will rattle early on but eventually clunking
5) Bad ball joint or tie rod can rattle as well
Never permit any shop to do expensive work on your car w/o first getting a second opinion somewhere else first. Do not tell second shop that you are there for a second opinion.
Shaking steering wheel at highway speed, no braking
1) Bad tire in front, bad tires in front, verify inflation of tires
2) Wheel alignment may be out
3) Front suspension parts (mentioned several above)
Highway speed to suddenly braking shakes steering wheel
1) Front brake rotors need to be inspected for warping
2) Test calipers on empty road at 40 mph, going straight on very LEVEL ROAD, hit brake pedal SOMEWHAT hard while barely touching steering wheel. If car jerks to one side, instead of braking straight on, you may have a caliper, ABS, or brake fluid pressure regulator off.
3) If brake rotors are warped, may as well replace front brake pads at same moment. Use ceramic.
4) When you drive on VERY LEVEL road on highway, steering wheel must be centered, let go lightly of steering wheel. Did car stay in middle of lane? No? Get a 4-wheel alignment.
Sep 13, 2010 | 2007 Toyota Camry
2002 toyota tacoma 4 door prerunner def. lock. was told it is blowing oil it is on the spark plugs. starts shaking very bad between 45 and 50 mph but not in overdrive. stops shaking at 52 mph. was when in...
2001 Toyota Tacoma Prerunner, 3.4L, 4 door, 2WD, automatic transmission overdrive problem. It's not shifting to overdrive, overdrive button on shifter does not turn light on - on dash. Mileage is 115,xxx.
Sep 07, 2010 | 2002 Toyota Tacoma
Car shakes
Theres mud on the inner side of the wheels, take a hose and clean it.
Dec 30, 2009 | 1996 Chevrolet Lumina Mini
1998 toyota corolla shakes before 2 rpm, check engine lights up
Not sure what is causing it, but it sounds like you're running on 3 cyllinders. Check plugs, wires, timing . timing belt may have jumped, bad injector, low fuel pressure.
May 13, 2009 | 1998 Toyota Corolla
Weak engine turnover / shaking engine
There could be a few possibilities:
1. Air Mass Sensor
2. Ignition Circuit Units
3. Dirty Idle Valve
4. Dirty Throttle Body
4. Voltage Regulator
Check the above one after another.
Jan 05, 2009 | 1998 Volvo S90
Quantum Fitness Q 3.0 Light Commercial Treadmill Logo
282 people viewed this question
Top Quantum Fitness Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a Quantum Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
