Question about Kodak EasyShare C913 Digital Camera
Batteries draining quickly
What would cause this problem? I have tried all brands and nothing makes a difference.
thanks
No longer need assistance. Thanks
Posted on Feb 19, 2009
I have an Airworks ceiling fan/light with remote. Worked fine for years. Now battery is being drained very quick.. in a matter of a couple of weeks! Replaced battery but it drains in a couple of weeks
Stuck button, spill on remote causing power drain or most probably you got a batch of weak batteries. Try a different brand and make sure they are alakaline.
Aug 15, 2016 | Dryers
Canon A520 powershot camera. You suggewted lithium batteries
Most likely a faulty mainboard which is causeing the powerdrain - replace the mainboard.
May 26, 2008 | Cameras
I have a 2015 ford fusion. On 3 different occasions I've tried cranking it and nothing. No lights and it won't even turn over. It cranks after being jumped off. Dealership says nothing is wrong with it....
You have parasitical battery drain. Here is a link for you to check what is causing the drain. Many time a after market alarm system cause a parasitical battery drain as its circuit is always on.
1. https://www.youtube.com/watch?v=KF1gijj03_0
2. https://www.youtube.com/watch?v=Y0HjaR0tj7Q
Mar 22, 2015 | 2015 Ford Fusion
Fitted new battery to my x5 today. First time I've seen a drain tube on a battery. I didn't attach it...is that an issue?
Yes it is,you need to find out the type of battery you replaced.
the plastic tube you see it is to stop idrogen reaction while battery produce when charged from other device.
All batteries brands differ from each other,please find out your brand and ask about the kit. BMW has nothing to do with this, it is something about batteries companies.
hope i helped you a bit so do not forget to click on the best answer.
thanks
provided from keep calm the best on Fixya
Nov 25, 2014 | Cars & Trucks
I just put in a brand new battery and it won't start. Absolutely NOTHING! Any quick suggestions? Fuse?
It can be the fuse link from the battery which could have failed and so will not power the igntion circuit. Please use a multimeter to trace the +12 to the fuse box and from the Ignition circuit.
Make sure the GROUND connection is good from the battery to the chassis.
Jun 06, 2012 | Dodge Dakota Cars & Trucks
Will a low battery cause a black screen
Low battery may also cause of black screen but not all the time it is a case to case basis. But if your battery is fully and you even plug it directly to the power source to the wall but still having the issue, well, that is different. But don't worry I have solution for you.
You turned on your laptop and horrors upon horrors, the screen is BLACK! You see that the laptop has power but besides that nothing is happening. I want you to know that there is a very good chance you can get out of this situation quickly and without any cost. This fix works on all brands of laptops:
1.
? 1) TAKE OUT YOUR LAPTOP BATTERY
? 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
? 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS
2. That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
3. Did this help you? If so Mo Bradley has one more quick tip to save your pocket.
I would like you to save on the high cost of replacement printer ink and I implore you not to buy Original Brand replacement ink. This is the rip off of the century and the Original Brand companies are not even ashamed. Try this website http://www.usainktank.com/ for ink which is mostly under $4.00 each (even HP ink) or if they don't have your printer model try some of the other suppliers of off brand printer ink. In the past I have used http://www.4inks.com/ and http://www.123inks.com/. They all have good quality off brand cartridges that will save you so much money.
I hope you find it very helpful.
Thank you for using fixya.com
Jul 25, 2011 | Acer Aspire 5735 Notebook
When i charge the phone the battery dies quckily
Please change the catergory, this is not a problem with a laptop, and please provide more information on the phone next time. Thanks!
May 19, 2011 | Computers & Internet
Hi there, I have a MiproACT-707 TM, which i use while teaching aerobics classes. After working perfectly for about 10-15 minutes - it stops working completely. This happens with brand new fully charged...
Hi, I would first ask if you are using a Ni-cad rechargeable battery system, these are not optimum performers for such a high drain microphone as probably the one you're using. Especially if the mic. takes a single 9 volt battery ( the average ni-cad 9 volt is about 200 milliamp hours, not a lot. If so-try switching to nickel metal hydride ( Ni-Mh ) these are better for high drain devices and do not develope a " MEMORY " effect ( which will cause rather sudden power loss ) memory effect can happen to almost brand new batteries as well, all it take to incur this is to charge a Ni-cad before it is totally dead. good luck, and thanks for choosing FixYa-Prodzilla
Apr 20, 2011 | Mipro Audio Players & Recorders
Battery drains too quick for AAA
it some times depend on the type of batteries u get.......
You should try to get three types of higher brands of batteries...
if that does not work get Litium rechargeables....with the chager..
Jan 10, 2009 | Coby MPC-848 MP3 Player
Battery drained and now lens wont retract and ive put brand new fully charged rechargeable batteteries i9n and still wont power opn or anything
I have the same problem.I forgot to get the battery from the camera s when we get the battery inside the camera then charged the battery when we put the battery to the camera it didn't work and no power, I've tried fixing the camera what's the problem and I think it was drained.I've also tried to go to the Canon company technician and they told me that there's nothing that they can do cause it was damaged already and they told me to just new one but my camera is just new s please help me what to do or any solution...thanks and here is my email baby_sykrich@yaho.com.
Nov 11, 2007 | Cameras
Kodak EasyShare C913 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
