Question about Music
I need a volume pedal for a SX KN6000 Technics keyboard
I bought a Yamaha FC7 foot controller - it works, but backwards. When you push down it goes softer (or quieter) instead of louder. There must be a way to reverse the polarity? to make it go louder the more you push down?
  • 3 Answers
Reversing the two wires inside the cable will NOT reverse your problem. Believe me: I tried it with a Behringer FCV100 volume pedal (which I have the same problem with and it's probably the pedal YOU NEED as the FC7 works correctly on my keyboard).
Don't waste a good 1/4" cable on that theory.
Posted on Nov 30, 2010
    Problem Solver:
  • 9 Answers
As there's no polarity switch on the FC7 the quick and dirty way is to cut the cable and swap the wires around.
Posted on May 28, 2009
  • rockinroller Nov 30, 2010
    Reversing the two wires in the cable will NOT reverse polarity. I tried it: Believe me.
Yamaha FC7 Pedal not operating
Make sure the shaft is turning the volume pot, if so, then potentiometer is bad OR has a bad connection. The cord is probably the cause from being pulled on or the plug needs re-soldering.
Feb 20, 2013 | Yamaha FC7 Pedal EXpression
Technics sx k350 keyboard user manual
Can you please scan and send it to my e-mail (op.mustonen@gmail.com) if I get it then I will send the money to you. I am leaving in Finland. Question is Technics sx k350 keyboard.
May 30, 2012 | Music
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Hello I got a technics kn400 broken and i try to fix it... It does nothing when powered on... Does anybody have the service manual for this keyboard? Thanks in advance Akis
Check the power supplies... beyond something pretty simple you won't have much of a chance of fixing if it is on the main board. Technics is really out of the business for the most part... they are a part of Panasonic. Expect to find voltages of +5 and +/-15 volts.
You can download a service manual for a KN6000 here and just MAYBE find enough simularity:
http://elektrotanya.com/technics_sx-kn6000-sm.pdf/download.html
Scroll down to the "Get Manual" and click on it to start the download.
Apr 10, 2011 | Music
I just bought an M-Audio Keystation 88ES. I have a used Behringer expression pedal. The pedal works fine in the sustain input, but when I insert the jack in the volume input it cuts all power to the...
If the power goes off when you plug in the pedal, the pedal LIKELY has a short in it between two of the three connections at the plug.
Firat, try putting the pedal plug in BEFORE applying power.
Likely the pedal presents a pot or volume control that will have like 5 volts across it an the wiper returned on the same cable. If the wiring configuration is wrong OR if the plug goes through a period of shorting the 5 volts out during insertion that will cause a problem...
To troubleshoot, move the pedal to half way and these with an ohmmeter for shorts between ANY two of the three connections.
Jan 28, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
What should I do for connect the fc7 to Roland RD-700sx for controll the loudness? Thanks a lot Heinz
Yamaha pedals MAY not work on the Roland... However, read page 85 of your manual regarding the FC1 and FC2 jacks. plug the pedal into one of them and then assign/select that jack as controller #7 (CC7) which is the volume controller number used in MIDI.
Jan 23, 2011 | Yamaha FC7 Pedal EXpression
Hi, i purchased yamaha fc15 sustain pedal yesterday. when i connected this pedal to my Roland E-09 keyboard through foot switch port, it activate Start/Stop button ( of arranger & song controls ) and...
The answer is NO... Roland uses the opposite sense switches on foot pedals... They use NIRMALLY CLOSED and your Yamaha is a NORMALLY OPEN switch.
SOMETIMES you can open these pedals and find that the pedal has the opposite sense switch available and you only have to unsolder and move one wire to make it a NORMALLY CLOSED pedal.
Dec 24, 2010 | Yamaha Fc5 Sustain Footswitch
Thomas jester 132 organ troubleshooting E-flat below mid c not working correctly on either keyboard or foot pedal all other keys ok volume pedal is scratchy but works ok
Here is where you can get the service manual:http://celedoniaorgan.netfirms.com/cosco/nfoscomm/catalog/product_info.php?products_id=1021&osCsid=3eaaa99d6bfceeaaf9b844687ba58d55 Since the problem is with the foot pedal note and the keyboard note I would suspect that there is a problem with the tone generation circuit for that note. You might try cleaning the key contacts on both for that note first to see if that works. The volume pedal probably just needs the volume pot cleaned with contact cleaner spray. I hope this helps. Let me know if it does.
Nov 26, 2009 | Music
Music Logo
490 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
