Question about Gateway Computers & Internet
EMACHINES m5312 HD Caddy
Still looking for the CADDY (Hard drive holder) for an eMachines M5312 laptop. The 2 replies have not answered the issue of the Caddy. One pointed to an entire motherboard and the other to a Toshiba Caddy???
  • Gateway Master
  • 4,806 Answers
Hi there
I do apologize for sending you to the wrong site, try this one, its from a uk site but i don't know what the delivery charge would be, but of course you can contact them;
http://www.usbnow.co.uk/External_HDD_&_Cases-2.5%22_Hard_Drive_Cases/c10_24/p182/2.5%22_USB_2.0_Mobile_Disk_IDE_Case/product_info.html?gclid=CMSP2Lb75pgCFZSD3godiVFWcA
Apologies again
Posted on Feb 18, 2009
Change key function f7
Click on this web site:http://www.2deals.net/Keyboard.html, can solve your problem.
Aug 11, 2013 | eMachines M5312 Keyboard
How do I remove the hard drive?
Depending upon your model laptop, the hard drive may be located behind a panel on the bottom of the laptop or it may be located on the side of the laptop and the retaining screw/s will be on the bottom of the laptop.
When you remove the panel the hard drive will be screwed to a hard drive caddy. Remove the screws on the caddy to release the hard drive. Keep these screws as you will need them to fix the hard drive to the caddy.
Feb 11, 2012 | Computers & Internet
I reformatted by emachines m5312 but windows xp can not proceed to windows setup-setup is starting windows and it turns off the laptop
Windows is very fussy about the hard drive being formatted
I would try a different Operating System just to be sure the rest of it is OK
The fix for you is to verify that XP can be installed with your disk.
Try a different hard drive
This is an extremely difficult problem. You may want to take it to a shop and have them install XP for you.
Apr 20, 2011 | E-Machines M5312 Notebook
Since reinstalling my emachine laptop it wont pick up any wireless network
The driver for the wireless is either missing or not working. Go to emachines/Gateway website and download the driver for your model/serial no.
Aug 22, 2010 | E-Machines M5312 Notebook
How do I clear the BIOS drive lock on eMachine notebook M5312
you can't. you need to replace the hard drive, that's the solution. there's no easy way around this feature.. it's specifically desiged so if the computer is stolen the drive becomes inaccesible.
Mar 26, 2010 | E-Machines M5312 Notebook
Specifically where is the hard drive for the toughbook cf- 27 - i've looked all over
Flip the laptop over and slide the 2 tabs that are near the carry handle to the unlocked position. This will allow the metal cover on the underside of the laptop to hinge up and be removed.
With the laptop upside down and the carry handle facing you, you should see the battery on the left of the laptop. On the right, there is a silver case about 4 inches long and 2.5 inches wide. This is the hard drive caddy.
To remove /this/ part, carefully push the connecting cable towards the battery until it smoothly disconnects from the hard drive caddy. Remove the caddy from the laptop. Using a small phillips screwdriver, remove the 3 small screws which hold the top of the caddy on. Remove the top, and you will see the hard drive.
As a note - be sure you do not remove the gel lining. This is 99.9% of the hard drive's shock protection. When you remove the hard drive, the cable should come out of the caddy as well. Put the new cable on a new hard drive (HDD must be smaller than 65,536MB), put the new hard drive into the caddy with cable attached, make sure the cable assembly is fitted into the caddy slot, replace the caddy cover, replace the screws, replace the caddy into the laptop. Then, make sure you connect the cable from the laptop PC board to the caddy cable assembly. Replace cover, turn on computer, and set up your Operating System (if needed).
Nov 10, 2009 | Panasonic Toughbook CF-27 Notebook
My laptop, emachine m5312 shuts down by itself despite the power settings to stay on, any ideas?
it may be set to hibernate in the bios. if it's randomly shutting down while you are working then you probably have an overheat issue.
Aug 14, 2009 | E-Machines M5312 Notebook
Need HD Caddy for Emachine M5312. Not System board, Not HD but on
Hi again
I have found a US site for you, if its an empty caddie you need they at the bottom of the page:
http://www.thefind.com/computers/info-hdd-caddy
Good luck and thanks for using Fixya!!!
Feb 18, 2009 | E-Machines M5312 Notebook
Hard Disk upgrade
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Aug 25, 2008 | Acer Aspire 7720 Notebook
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
