Question about Kenmore 62802 Electric Dryer
With timer on dryer stops spinning when door is open but heat won't shut off
  • 188 Answers
The element might be shorted and grounding itself to the element housing.
Could also be the centrifugal switch in the motor or the contacts in the timer.
Posted on Feb 19, 2009
How do I stop my dryer from spinning?
Could be bad timer but check the timer knob first have seen them crack so they are not pointing in the right direction
Dec 09, 2015 | Dryers
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
I have a Maytag PYE2200AYW electric dryer. we had problems a few weeks ago and discovered that the blower wheel was cracked, so we replaced it (part # 31001317). Then a couple days later it just stops and...
Check the thermal fuse and thermostats again to eliminate them as suspects. Both should be zero ohms at room temperature. If you eyed the entire duct system from lint filter to outside of the house for lint, then these are probably OK.
One thing that will shut down a dryer: a defective door switch. If you turn the timer on with the door shut and can hear or see it progressing (running) then the door switch is OK.
If your door switch is operating marginally, the heat can expand the body of the switch and open the circuit (and shut the dryer off until it cools). Check the switch with an ohmmeter with the dryer disconnected from power.
A loose spade terminal on this switch (or anywhere else) can do this too.
Also, a misaligned door or defective door clasp might do this after heating up.
Keep thinking 'heat expands' and you might find it.
The only other thing left is a defective timer.
Good luck from Detroit, MI.
Jun 11, 2011 | Maytag PYE2200 Dryer
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
What's wrong with my dryer & how do I fix it? Kenmore 70 series dryer won't shut off!! It stops when the door is open but won't shut off on it's own.
If the timer just keeps going past the next off and never shuts off then it could be one of two things. First, is the heating still on when door is opened? If it is then the electric heating element is broken in half and one half is getting neutral by laying against the metal heater case which will cause this problem. (assuming a electric dryer). If not then the timer is the culprit and check fleabay for NOS.
May 01, 2010 | Kenmore 62602 Electric Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
Kenmore 62802 Electric Dryer Logo
59 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
