Question about Epson Stylus Photo R260 InkJet Printer
Flashing red lights
My Epson R260 won't print. I replaced an ink cartidge and afterwards the red lights for ink and paper alternate flashing.
  • fran piraino Mar 05, 2009
    I have the same problem, flashing red lights, i know it should not be the ink pads the printer is almost new. i can remove the cartridges and it still flashes red. i did try reseting the ink pad, but it says it is not needed.. any other solutions i can try.. thanks
    fran
  • Anonymous Mar 17, 2014
    Hi! 1st of all my English not good,i have replace R290 main board into t60.not the red Ink light is still on and shows problem in all color .help me ,Plase.
  • Epson Master
  • 541 Answers
This means your printer wast pad is full but your printer can be reset let me no and i will send you the info on now to reset your printer
Posted on Feb 19, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Two red lights flashing, but i can't figure out what's wrong
According to the documentation for your printer.
Red probsolv.6.3.11.jpg paper and probsolv.6.3.12.jpg ink lights flash alternately Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, contact your dealer or Epson as described in Where To Get Help.
Dec 16, 2010 | Epson Stylus C86 InkJet Printer
R200 both red lights flashing
if both red lights are flashing alternately your printer has been locked this is due to full waste ink pads. you need to have them replaced either at your local service centre or do it yourself then you need a scss reset utility to reset your printer you can get a free one of these on the net
If your lights are flashing continuously look to see if you have any outstanding documents in your print queue and delete them
Mar 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
My red lights are both flashing and printer will not responed
Both red lights flashing? One should be for paper jam and the other for low/insufficient ink. I presume this is a deskjet/injet printer. The combination of these two lights flashing usually indicates a more serious issue rather than just low ink or paper jam. It is indicative of incompatibility of ink cartridge. After a while some cartridges just could become incompatible with the machine. All things being equal (i.e. no paper jam issue) a replacement of your ink cartridge will resolve this issue. Just get brand new ink cartridge/cartridges. It is usually ok to replace only the one that has become incompatible. But the issue is you need to troubleshoot to determine. You may not have the resources to do this, so better to replace both or replace one-by-one.
Sep 15, 2009 | Epson Stylus Photo R260 InkJet Printer
Ink cartridge are full yet the red light is still on...
1. Disconnect the USB from the back of the printer.
2. Ensure you have the correct part number on the Cartridge.
3. Push the red button and make sure it indicates the Black is out (if another color is out, it won't print and even if u only ever print black the color still runs out)
4. Re-seat the cartridge
5. Try another cartridge
6. If that doesn't work, your printer needs service
May 13, 2008 | Epson Stylus Photo R260 InkJet Printer
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R260 InkJet Printer Logo
860 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
