I have to repeat the key several times and it looks very messy when finished.
SOURCE: Nakajima AE-830
The typewriter is set in P.S. mode instead of 10 or 12. This switch is in lower left corner of keyboard.
SOURCE: AE-710
First see if the ribbon is spacing a full space for each letter pressed if not you may be in the over strike ribbon mode, to get out of the mode press code and comma, period or slash i'm not sure which one So try them all.
If that dosen't help check to be sure the correction tape is not getting in the way, remove the corr. tape and try it.
Next remove the ribbon and release the hammer as if you were changing the P/W and see if the plunger in the solenoid is free, if not try a drop or two of WD40 on it.
DickyO
SOURCE: Nakajima Ax-510
CALL REPAIR SHOPS. GOOGLE IT. YOU CAN PROBABLY REPLACE THIS EASYIER AND CHEAPER THAN FIXING IT
SOURCE: Nakajima AE 800 will not underline words with new ribbon
We have had new cassettes that are faulty. The quickest way to test is to change a cassette from a machine that is ok onto the faulty one. If the problem goes away then the cassette that was on the machine is faulty.
SOURCE: Ribbon Cartridge for Nakajima AE-740 Typewriter
It takes a General Ribbon t325 we have them in stock @ 6.50.
DickyO
Cleveland Business Machines
216-241-0027
