Question about Singer 5062 Mechanical Sewing Machine
Putting the bobbin housing back together
My mom took the bobbin housing apart to clean teh machine but never put it back together. Where can I find schematics so I can fix this? I need a visual to look at.
  • a45princess Feb 18, 2009
    It's a singer 4562 not 5062
    Sorry
Found your problem while I was trying to solve mine. I can solve yours. Here is the page from my manual about how to remove/replace bobbin housing. I hope you can make this image larger so you can see it clearly. We're limited as to the size of the file we can upload.
Posted on Apr 13, 2009
  • 25 Answers
What I had missed was the little silver plate that is needed to keep the black plastic part down. So when sewing it kept pulling the bobbin and the black plastic part up, making a clacking sound and resulting in no stitch. Thank you.
Posted on Feb 08, 2010
Took my machine apart to clean & oil. Now having concern about how to put hook assembly back together. I have a manual but photo doesn't show enough detail!
This video is about removing the items in the bobbin area to clear thread tangles, but the instructions may help you figure out how to put them back together.
30 Removing Tangled Thread from the Hook Race FREE
Jan 26, 2016 | Sewing Machines
I took apart my top loader bobbin case and don't remember how to put it back together. please help.
go on line to asked.com they sometimes have videos on how to's there
Oct 10, 2014 | Sewing Machines
I cant figure out how to put the bobbin carriage back together on my brother vx1010
I think you're talking about the shuttle and race. It goes together like this: http://www.manualslib.com/manual/85659/Kenmore-385-15208.html?page=68
Jan 21, 2014 | Brother Sewing Machines
I cant put the inside of my machine back together
what is the name and model number of the machine ?
do you have a manual?
Dec 03, 2012 | Bernina Sewing Machines
I took out the inner workings of the bobbin holder underneath the machine to try to clean out some clogged up thread, but I can't seem to get it back together. Suggestions?
You should have 3 pieces that make up the parts of the hook and bobbin case that you can take out to clean. 1 the bobbin case, 2 the race ring, 3 the hook. The easiest way to reinstall the hook and race ring is to tilt the machine and lay it on it's back. If you have the bobbin door open, and you rotate the handwheel and look inside the hook area, you will see the driver rotating back and forth. You want to set the hook inside the hook housing facing opposite the driver. As if your putting two halves together. Next install the race ring, shinny side out. Most of the rings have a nipple at the bottom that fits into a slot in the hook housing. Next lock the race ring in place with the 2 black or chrome arms that you swing inward. All you do next is install the bobbin case. Your done.
May 01, 2011 | White Sewing 1755 Mechanical Sewing...
Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
May 27, 2009 | Singer Sewing Machines
I took my maching apart to clean the lint out and when I put it back to together the needle is hitting the feed dogs. what could be causing this!
most likely the bobbin case is not aligned correctly .Insert the bobbin case so that the projection on the boobin case aligns with the spring.
Feb 23, 2009 | Brother CS-6000
Putting back the pieces of bobbin case on Kenmore Mini Handi
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine 30 degrees on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
Feb 27, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Singer 5062 Mechanical Sewing Machine Logo
1,763 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
