Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
My clean dishes from my kitchen aid dishwasher have a nasty odor! I have tried 2 methods of cleaning the dishwasher (which is only about 1 1/2 yrs. old) and had no luck. this has been happening for many months. the scent lingers on the clean dishes and they need to be washed by hand to get rid of it.
  • 640 Answers
Start with empty dishwasher,,,add a pint of bleach and rinse on short cycle..onthejob
Posted on Feb 18, 2009
My kitchen aid dishwasher has an off odor and is leaving a residue on the dishes. what should I do?
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Apr 03, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen aid dishwasher, 3 yrs old, dishes on top rack do not get clean
On your model, upper rack cleaning issues are most often linked to debris in the inlet to the pump. I have put some instructions together on cleaning this. If you follow the link it will explain how to check and clean this.
Sump Clean Out
Aug 22, 2010 | KitchenAid Dishwashers
Dishwasher always has a nasty odor when you open the door
check the drain hose connection from the dishwasher to the main drain under the sink , it should be connected above the trap . hope this was helpful
Jul 11, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Does the two drawer use liquid or powder soap? Kitchen Aid Dishwasher is not washing things clean, there is a coating of dirty food particles on the dishes. Help!
About the soap: You can use both. I prefer tablets.
About the particles: Before putting the dishes in, remove the food with a brush ($2.00) in the sink and run the hot water from the faucet for a 1-2 min until it gets really hot.
Sep 30, 2009 | KitchenAid Dishwashers
Dishes not clean and some have gritty film after wash
Popular Science or Mechanical Ill. recently suggested to take the drain cover at the bottom of the unit off and use a shop vacum to clean and clear out the sludge and accumulation in that section it may **** up and solve the problem,at least it is worth a try.
Apr 12, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
188 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
