Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
It will not dry. The dryer spins but no heat.
It will not dry. The dryer spins but no heat is produced. Washer works fine.
  • 640 Answers
Check thermo fuse,,,onthejob
Posted on Feb 18, 2009
Hotpoint WDD960 Washer Dryer - no error code but whenever I put it on a dry cycle it just spins as if working but without actually drying. Any suggestions?
Sounds like heating element is not coming on ..Heating first then with a Fan motor running and water flow the steam that is produced by the heaters are changed to water by the cold water over a condenser , the pump then puts his out to waste..
Jan 28, 2011 | Hotpoint Washing Machines
Dryer is not working
The air heater and the blower requires to be tested/checked.
Apr 06, 2010 | Malber WD1000 Front Load Washer/Dryer
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
My dryer spins and heat just a little but not enough to dry any clothes
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Jan 08, 2010 | Estate EED4300TQ Electric Dryer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Smeg wdf1 washer dryer not drying clothes. Wash cycle fine but no heat produced when drying- any idea where to find/check the fuses/elements?
Hi, Take the top cover off and click the little red button on the thermostat/overload (small black box). Then try again. Sometimes these trip out as a safety precaution.
Jun 13, 2009 | Smeg WDF16BAX Front Load Washer / Dryer
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Dryer won't heat
If it is an electric heater that means that either the heating element,or the thermistor , or the cirrcuit breaker connecting the element mustbe replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryer not working
If the drum is not moving: There is something stuck inside your furness blower( could be some pice of cloth). Open the furness and remove the piece and your dryer will be working fine afterwords. If the Drum is working fine; the coil valve, fuse or the gas ignitor could be the problem; usually repacing the coil valve will fix the problem
Oct 14, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
452 people viewed this question
Dan Webster
Dan Webster
prem mathew
