Question about Aspyr 1701 A.D. for Windows, Mac
Nothing happens i put the install cd in my computer and nothin happens its like my computer cant read it. How do i fix this?
  • louisrd2003 Mar 15, 2009
    cd rom doesnt even notice cd is in cd rom drive
    Scholar:
  • 164 Answers
What OS are you running? if it is Vista, it will not work.
have you defragged the computer this month? if not, that could be an issue. How many items are actually running in the back ground? To find out, hit the CTRL/ALT/DELETE.
Then look at the start up tab on the right. if there is more than 5 items checked, that could be the issue. White there, click on the tab called performance. If your processor is above 40%, that can cause this as well.
Posted on Feb 19, 2009
I just installed my new LG super Multi DVD REwriter and the light comes on but nothing else happens I put theinstall disc in and still nothin happens...
check the power leads that attach to your lg external dvd drive make sure they are securely seated and consistent power is getting to it also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Sep 01, 2011 | LG SecurDisc 20x External Double-Layer DVD...
I'm having problem to put the car in timing or time I try 3 times but nothin it wanted to start but nothin happen what sould I do...
get a code reader the timing is fixed you cant move it try cranksesore ground wire not the battery one the on the block firewall fender fulepump fuse..
May 08, 2011 | 1999 Plymouth Breeze
My computer won't read disks.
There's only two possiblities either your driver has been corrupted or the drive itself has failed. Try reinstalling the driver, first find or download the driver for your CD drive, when windows tell you it already has the best driver hit back and tell it to install the driver at the location where your driver is at. If this doesn't fix the problem your best fix is to buy a new CD drive, given the current cost of DVD drives this might be a good time to upgrade.
Jul 05, 2010 | Dell Dimension C521 PC Desktop
Wont install
1st You download Webcam Driver.
Wont install
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Apr 08, 2009 | PC Concepts 300K Webcam
Just spins
This sounds like a samsung drive, the laser is probably dead or on its way out or it could also be the small belt that is stretched and to weak to shut the drive properly, either way the machine will need to be stripped down and repaired.
we can get this back to normal for you just email us at www.fixmyconsole.co.uk
Feb 21, 2009 | Microsoft Xbox 360 Console
Nothin works and nothin is detected
doesnt need batteries does it dl latest driverers form website maker try ohter ports
Oct 09, 2008 | Microsoft Wireless Optical Desktop Comfort...
My Computer Wont Read DvD's or CDs!
Is the CD drive display in my computer? yes
then clean up your CD/DVD rom for there is dust in it, specially on the lazer lens that let the rom read the CD/DVD.
If no, then; Fix some cable connection towards your CD/DVD rom for it was lessen.
If not fix the problem verify the disc if it is readble by your Rom. Please try another disc in your Rom.
if same happen, then maybe its time for a new CD/DVD ROM.
one last try:
try your new purcahse disc in another computer that is compatible with your disc.
hope this help, melnavz
Feb 05, 2008 | Dell Dimension 3100 PC Desktop
I cant download songs
download music to mp3
Jan 31, 2008 | iLO (2 GB) MP3 Player
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
Proline Digital MP3 Player
Check in My Computer and be sure the device shows up as a drive letter. If it does not, be sure there is a free drive letter available that it can use. If not, check in Disk Management and assign it a letter.
Jan 02, 2007 | Nolo Dealing with Problem Employees: A L...
Aspyr 1701 A.D. for Windows, Mac Logo
176 people viewed this question
Top Aspyr Video Game Consoles & Games Experts
James Wishart
Are you an Aspyr Video Game Console and Game Expert? Answer questions, earn points and help others
