Question about GMC Yukon XL Road Bike
When shifting gears the chain starts to hop.
When shifting gear the chain starts to hop. but this problem only occurs on some of the gears.
  • Christian Samuelsen
    Christian Samuelsen May 11, 2010
    which gear combinations exactly?
    Front set and rear set are read as "1 to (whatever)" from the center of the frame ( as seen when sitting on it, like when you ride!).
    SO: the front set will be 1st 2nd / 3rd
    AND: the rear set: 1st -5th / 6th / 7th / 8th / 9th / 10th
    Therefore: when riding in 1st (front) and 10th your chain will be on the smallest, most inside gear in the front and the smallest most _outside_ gear in the back.
    Now what gear was that it hopped in?
  • 37 Answers
It is likely that your chain, coggs, (rear gears), and front sprockets are all wearing out. The gears wearing out now are likely the ones that are used the most. You will probably have to replace the chain, coggs,(freewheel), and maybe the front sprocket that is used the most refer to Parktool.com
Posted on May 22, 2009
Shifting gears
when shifting gears on bikes you have to keep pedalling but with out load on the chain
shift one gear at a time as multiple gear selections may cause chain jump
do not pedal backwards as the selector is for forward motion only
Jul 25, 2015 | Cycling
I have a 1996 Dodge Dakota. 3.9L V6, 5-speed manual, 206,334 miles. For some reason, when I shift into second gear, the truck suddenly goes from gaining momentum, to literally "chugging" along. When I...
have the trans checked out, sounds like it might be in 2 gears when your shifting into 2nd, causing it to bind up, is there any noise when this problem occurs? a bad bearing or worn syncro rings could be the cause
Sep 01, 2013 | 1996 Dodge Dakota
My 2000 Protege is a manual shift. Just recently, when I'm in 1st gear and I let the clutch out, the car awkwardly hops forwardly. I quickly shift into 2nd and that gear is fine. Why is my car doing this...
Sound like first gear is going out on you. It could also be an issue with the clutch. If the car has enough power try to take off in second gear and see if it hopes. If it doesn't there's likely a problem with first. Unless you are a certified auto mechanic, it's probably best to bring it in and have them conferm that it is a problem with the gear and have them take care of it. It might mean replacing the transmission.
Oct 15, 2010 | 2000 Mazda Protege
When peddling bike seems to try to shift gears
There may be some chain links that do not move freely. turn the pedal slowly backwards and check for siezed links, as it goes through the deraileur.
A worn chain can do this as well, unfortunately you usually have to change the chain and sprocket cluster as a pair. If you just put a new chain on a similar problem can occur.
Apr 22, 2010 | Schwinn Mesa Gs Mountain Bike
Problem with chain and gears
Wash, degrease and scrub the chain and derailleurs with a good degreaser (like Simple Green). Dry the chain and relubricate it with an appropriate bike chain lubricant (not oil or WD-40). Shift the derailleurs to the smallest chain ring and cog on the cassette (low front gear, high rear gear) and then loosen the cable at the derailleurs, pull the cables taut and reattach them. If the derailleurs still need adjustment, here is a procedure for it:
Flip the bike over (so you can pedal the bike manually while you shift) and shift the front to the middle chain ring. Shift the rear to the highest gear (small cog). Release the cable from the pinch bolt on the derailleur. Adjust the screw marked "H" on the derailleur until the jockey wheel on the derailleur is aligned perfectly over the small cassette cog. Set the cable adjuster on the derailleur to the middle of its range (find this by screwing it all the way in and then count how many revolutions it makes until it screws out completely. Screw it back in one half of the total revolutions). Reattach the cable and shift to the lowest gear (the biggest cog). Over-shift and hold on the shifter, then adjust the "L" screw on the derailleur until the jockey wheel sits just past the last cog. You have to hold the shifter to do this. Now shift into the middle gear (or one of the two middle gears if the bike has an even number of gears) and adjust the derailleur using the barrel adjuster you previously set to the middle of its range. Adjust it so that the derailleur is sitting perfectly over the appropriate gear. Shift up and down the cassette while pedaling and in every gear, reverse pedal (freewheel) to make sure the chain does not hop. Adjust as necessary until all gears are smooth.
Now the front:
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
That should be it, unless there is another mechanical problem causing the missed shifts, like a bent derailleur hanger or damaged teeth on the cassette cogs or a bad derailleur. If it is still problematic, come back for further information.
i hope this helps
-matthew
Oct 26, 2009 | Cycling
Chain coming off fron gear when coasting or trying to pedal backwards? Local bike repair shop indicated that a bearing maybe shot but that they couldn't replace the front gear unit.
Oh, it is too bad you are in the Bronx. i'd have that fixed right quick. There are probably a pair of culprits at work here. One, your derailleurs no doubt need adjustment. Two, your rear derailleur hanger may be bent. These two can both cause the problem. Start with the rear hanger, because that will be easier to see.
Flip the bike onto the bars and saddle and take a look at your rear derailleur. Is it going straight up and down and is it aiming straight with your frame? If it isn't, you have found your problem. The hanger needs to be straightened. This can be done without any tools if you have a good eye. Hold the derailleur by the body and bend it to make the alignment good with the cassette. If this is NOT the problem (but i really think it is) then here is a walk-through on adjusting your derailleurs and hopefully this will solve it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
Sep 16, 2009 | Cycling
I'm trying to adjust the shimano gearing on my trek bike and am having a little trouble
Front or rear? What is it doing?
Flip the bike over onto the handlebars and saddle and let us fix it.
Sep 02, 2009 | Cycling
I had bought a Titan Glacier unisex 21 speed middle gear will not
Here is link that might help:http://www.parktool.com/repair/byregion.asp?catid=53. Also sight from back to front along the chain. The cage of the front derailleur should be parallel to the chain along its length in all three positions. Hope this helps.
Aug 16, 2009 | Cycling
No power to the wheels
ok bro' couple of things going on here. we'll start with the starter haha! how does it start you ask? the starter button hots up the sarter motor with the 12 volts dc which engages the starter gear wit the CLUTCH BASKET which has a ring gear in it and of course the starter is spinning and it spins the clutch basket and pulls on th primary chain if your fatpunk I mean fat boy is stock and pulls on the motor sprocket and turns the motor. If no motor power to the wheels and no starter power to the motor then something in between is broke. so I think the clang you heard was the demise of your primary chain or the clutch basket or the engine sprocket I think the primary chain is most likeley. so take it easy off the line until you hop it up proper son it ain't no hot rod til you drop some mods on it
Apr 17, 2008 | Harley Davidson Harley-Davidson Motorcycle...
GMC Yukon XL Road Bike Logo
123 people viewed this question
Top GMC Cycling Experts
Mike
Arnie Burke
Arnie Burke
Donald Ayers-Marsh
Are you a GMC Cycling Expert? Answer questions, earn points and help others
