Computers & Internet Logo
vic naylor Posted on Feb 26, 2013
Blue screen when usb plugged in to new board old xp home
This is a brand new board just plugged in the only available h/d [sata] with xp home boots and runs ok until you plug in any usb device then blue screen error 0x0000007e
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Feb 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
Helped
1396
Points
11
1.) Ensure XP is updated with latest device drivers
2.) Ensure latest chipset & motherboard drivers are installed
3.) Check USB drive, and USB port
4.) Boot up with any Linux OS Boot up disk and check if USB is working
5.) Install Windows 7 in case new drivers not available on XP
5 Related Answers
A
Anonymous
  • Posted on Mar 12, 2007
SOURCE: No HDD Found on initial XP Install
Make floppy for SATA, when start instlling Windowz press F6 and this is it!
colliewob
David
  • 781 Answers
  • Posted on Nov 04, 2008
SOURCE: PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Anonymous
  • 4 Answers
  • Posted on Dec 21, 2008
SOURCE: on board USB ports not working
Right click the mouse on My computer located on desktop- select Manage- select device manager- find universal serial bus controllers - click on universal serial bus controllers - u find some devices there - right click the mouse on each and select uninstall - after uninstalling restarting the computer.
note : ensure usb controllers are enabled in BIOS setup for this , u should press delete key  at the startup of PC and locate it in Intergrated peripherals
Anonymous
  • 32281 Answers
  • Posted on Oct 10, 2009
SOURCE: run a sata drive as main boot up drive
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Anonymous
  • Posted on Jan 12, 2010
SOURCE: P4VMA-M motherboard won't recognize SATA hard drive
http://img.photobucket.com/albums/v242/Saphirex/wdsata2.jpg
http://img.photobucket.com/albums/v242/Saphirex/wdsata22.jpg
1helpful
Asus motherboard problems Installed a new F2A55-MLK series to replace old ASUS board. Running XP and when I install the HDD it boots until the starting windows screen and get blue screen Asus tech no help.
go into the BIOS setup and find settings for SATA operation or something similar. the available options should be
1. Native SATA/IDE
2. AHCI supported
3. RAID
windows xp was installed with SATA support but requires special drivers for AHCI or RAID, so you should set your computer's SATA operation to native or IDE in order to solve the problem.
Additional tip:
next time you manage to boot to windows, boot to safe mode (boot while pressing F8), so you can review if all the drivers are well installed in device manager.
1helpful
Blue screen Dell Dimension 0x0000007B
plug the HD in other PC and execute Scandisk Complete
Blue screen upon instal of xp
Are you installing it on laptop?? If it is, try check your BIOS settings on the SATA mode option if available.. usually it is either ACHI or IDE. try to change it and try to install your xp again.
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Hello, my main board is asus p4p800-vm running xp home with sp3 upgrade with ide hdd's and is running well. i bought 2 new sata hdd's because the board has 2 sata ports, i set the bios to auto to see the...
Windows will not see them because you need to download the SATA drivers for the motherboard from the Asus site.
Download and install to a floppy or USB (advise the latter)
Install windows,and you will get a "press f6 if you want to install a raid device ..."
Press F6 and hopefully, windows will find the drivers, highlight the ones it wants.. the rest should be simple
3helpful
I had a compaq pesario cq40-421TU laptop .when i boot it with a windows xp cd the set up stop at the point of ''SATRTING WINDOWS'' and shows a blue screen and says some information like a number and the...
The stop error code is most likely STOP:0x0000007B because windows XP doesn't have the correct SATA controller driver to install without assistance.
Options:
If available, try setting the SATA controller in BIOS to ATA or Legacy Mode.
If not available, then you will need to download the SATA controller Driver and slipstream the driver into the XP version you are trying to install
http://www.fixya.com/support/r4439741-integrate_slipstream_sata_drivers_into
Blue screen
Check booting in other computer, this will show if CD faulty. If not, CD drive may be faulty. If CD not faulty & can boot from USB drive you can copy CD to USB drive and install that way.
Can't install Windows XP Home on Compaq CQ50-139M Notebook
I would run a deeper scan of the hard drive while hooked up to the SATA -USB enclosure. Try using either Seatools or Western digital Data lifegurad tools and run the long scans. If the XP CD is in fact SP-3 it should have all of the necessary drivers for SATA drives. I am suspecting some bad sectors and a possibly failing hard drive, which would also explain why Vista froze.
These diagnostic tools can be found at:
http://majorgeeks.com/Western_Digital_Data_Lifeguard_Tools_d2855.html
and
http://majorgeeks.com/Seagate_SeaTools_for_Windows_d2858.html
1helpful
2nd sata connected and xp won't boot
It seems you have not made the second SATA the slave of first SATA. You'll have to fix the jumper pin in the designated slot to make the second SATA the slave. a1d66e3.jpg
Grand Canyon Tech
Grand Canyon Tech
