Question about HP LaserJet 2840 Printer
When printing, the printer makes a loud sound
I just replaced the imaging drum and after a few days, every time I a print a document, our HP 2840 will print it however, it makes a loud noise during the printing process. It sounds like trying to start a car and the battery or alternator is not functioning. Can you assist me as what is causing this noise???
  • 3 more comments
  • Anonymous Mar 01, 2009
    I have the same problem it makes a loud nose when printing.
  • safecheck1 Mar 22, 2009
    I just moved my printer and I am hearing the same loud beeping when it styarts to print.
  • Anonymous Apr 08, 2009
    I also have the same problem it makes a loud nose when printing. We think it may be the drum. Can someone help!!!
  • sbmedsupply Apr 30, 2009
    Mine just started earlier this week (it's 4/30/2009 today). Especially with the latest medical scare for masks, my printing needs have increased dramatically and it's only getting LOUDER and LOUDER! SOMEONE PLEASE HELP!
  • bill7878 May 18, 2009
    Mine Squeaks during calibration and receiving faxes. Anyone solve it
I first guess that it is the drum going out. If you have changed the drum......it is more than likely your fuser. Have you ran a supply check to get the status on your supplies?
Posted on May 08, 2009
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
HP Colour Laserjet 2840
Laser printers work by creating latent images on a rotating, light-sensitive drum and then attracting toner to exposed points on that drum. If any point on the drum’s light-sensitive surface is damaged, you may notice that toner is always attracted to that point, thereby transferring to the final page and appearing as a repeating mark. Because the drum is a cylinder, such marks will appear at equal distances down the page, corresponding to each rotation of the drum (maybe every two inches, for example).
The only solution to this problem is to replace the drum. For most low-cost home printers, the drum is part of the toner assembly and is automatically replaced each time you install a new toner cartridge (which explains part of the cartridge’s high cost). More industrial-strength laser printers place the drum on a separate EP (electrophotographic) “engine” that can be replaced in just a few easy steps. Check your printer’s documentation and replace the appropriate assembly (or have someone do it for you), and the repeating marks should go away.
Mar 14, 2008 | HP LaserJet 2840 Printer
We just replaced the imaging drum on our HP 2840. Now when we print in color, we get the image we printed, plus a lighter version of the same image about 2.25 inches lower on the page, every 2.25 inches. ...
A repetitive defect at that spacing points to the transfer roller. This is the roller in the bottom of the drum/cartridge cavity. Most likely you will need to aquire a Q3948-67920 transfer roller kit.
Mar 16, 2011 | Office Equipment & Supplies
Only right side of the page prints - help!
Marks repeatedly appear at even intervals on the unprinted side of the page.
c00366165.gif Internal parts might have toner on them. The problem typically corrects itself after a few more pages. The paper path might need cleaning. Click here to go to the Print Defect ruler for more information.
Clean the device. The imaging drum might be low. Click here to go to the Print Defect ruler for more information.
Replace the imaging drum. The fuser might be damaged. Click here to go to the Print Defect ruler for more information.
Contact HP Customer Care Marks repeatedly appear at even intervals on the unprinted side of the page.
Contact HP Customer Care hi at the link given below, click on it and locate the page (halfway down) where it states this
Contact HP Customer Carehttp://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=110&prodSeriesId=445194&prodTypeId=18972&prodSeriesId=445194&objectID=c00366102
Nov 04, 2010 | HP LaserJet 2840 Printer
HP2840 All-In-One. Makes loud squealing noise when calibrating & printing. As if it needs oiling.
thy taking the imaging drum out and power cycle. If the noise goes away replace it. If the noise persist it might be the carousel
Aug 24, 2010 | HP LaserJet 2840 All-In-One Printer
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
HP COLOR LASER JET 2550 SERIES
You will need to replace the image drum. This is either due to the face that you have exceeded the number of pages/cycles that the drum supports or the drum has damage. If this is the drum that came with the printer, it is likely they shipped it with "starter" supplies which last a fraction of the time as the regular "full retail" replacement supplies. A URL for HP's instructions on how to replace tn image drum on the HPCLJ 2550 series follows:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=388394&prodTypeId=18972&prodSeriesId=388394&objectID=bpl12241
Nov 08, 2007 | HP LaserJet 2550Ln Printer
HP LaserJet 2840 Printer Logo
860 people viewed this question
Seeker5211
Seeker5211
