Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
Pioneer SD-582HD5 Picture looks 3D with red and blue copies of images seperated on the screen..
  • mootehdan89 Feb 23, 2009
    I am having the same problem only my colors are blue and yellow shadows around the images. The solution posted is the convergence ic's what are they ? Where do i find them? how much and are they easy to replace in the tv?
  • Pioneer Master
  • 5,138 Answers
Replace BOTH of your convergence ICs they are big black ICs will have part number on them if 110s use 180s.
Posted on Feb 19, 2009
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
My picture is split. For example when text is on the screen the words are in red above and then again in blue slightly below. Is this an easy/cheap fix or should I get rid of the T.V.?
Based on your description, the convergence circuit has failed. If you looked at the tv menu do you see what may look to be 3D, double image, or a red picture and then blue picture slightly offset? The picture may be distorted as well.
A repair shop will charge about $300 to fix.
If you have soldering skills, an electronics background, an OHM meter, then its not to hard to do, just time consuming.
Feb 18, 2011 | Pioneer Televison & Video
My picture appears to be out of convergence but i cannot adjust it back. Looks like the green is off a couple of inches.
TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
The picture looks like a 3D with the egges curving in and colors seperated
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
Nov 21, 2010 | Sony KP-46WT500 46" Rear Projection...
Green and pink wavy through out the screen
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 16, 2010 | Pioneer SD-582HD5 58" Rear Projection...
Green and pink wavy lines throughout. Picture
I am having the same problem and so far unable to fix,
Jan 22, 2010 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Component video issue
You have a component not up to specs in your input 2 circuitry possibly a capacior. You would need a service manual to locate which item that isnt up to its rating. you can purchase the service manual for your set for 12.99 at the following link. They will emal it if you send them an email requesting it.
http://servicemanuals.vstore.ca/
Jan 04, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
165 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
