Question about Generac Guardian 0C3025 - oil pressure switch
Oil Pressure switch for 2001 Chevy Cavalier
Where is the oil pressure switch located on 2001 Chevy Cavalier and how do I change it
    Problem Solver:
  • 9 Answers
Two different engines:2.2 liter (most common) on right side of engine , towards firewall , same side as the oil filter.Single wire connector & wire color is tan with a black stripe. The 2.4 liter engine (Quad4) is located at the top rear of the engine same connector & same color wire. You will need a special tool. if not available a deep socket, or a big wrench or you can get creative with pliers.
Posted on Feb 18, 2009
Oil light come on and off
Posted on Aug 17, 2010
2 Suggested Answers
  • 9 Answers
SOURCE: cant find the oil pressure sensor location
what engine are you installing this on? V-6 or V-8 Chev should be rear of intake by the distributor.
Posted on Jan 24, 2011
Hi...Where is the Oil Pressure Sensor/Switch located on 1987 Chevy Cavalier, 4-cyl, 2.0 engine?? Thanks in advance!!
It is generally located in the vicinity of the oil filter. Here's what you're looking for.....
Apr 09, 2017 | 1987 Chevrolet Cavalier 4 Door
How do i change oil pressure sending unit on a 2005 chevy malibu
Hi Viv,here's a link to the oil pressure switch,it is located by the oil filter,it is screwed into the block,to remove, just remove electrical connector,then get a wrench and take off,very easy to do. Oil Pressure Switch at AutoZone com Best Oil Pressure Switch Parts for... HERE'S A VIDEO TO WATCH. FIX OIL LEAK How To Replace Oil Pressure Switch Oil Sender etc POV
Oct 01, 2015 | 2005 Chevrolet Malibu
Chevy 350 oil pressure sending unit
The Oil Pressure Switch is located:Under hood, center, rear engine area, driver side of distributor, mounted in block. Here's what it looks like.he oil pressure switch is mounted to the top rear of the engine.
  1. Remove the electrical connector from the switch.
  2. Remove the oil pressure switch.
  3. To install, reverse the removal procedures.
Jul 18, 2013 | Cars & Trucks
My oil pressure sensor started leaking oil through the plug.
pretty common same thing with my 2001 2 door chevy cavalier. its the valve cover gasket, you need to replace it.
Jan 28, 2013 | 2001 Chevrolet Cavalier
My oil light comes on. the car has oil. runs like a champ no noises of any kind sounds like it always has. iv been told its the oil presh senc going bad or has gone bad. any thoughts? its a 1999 chevy...
i'd agree sounds like a faulty oil pressure switch.doing a pressure test with a guage will
tell for sure or just replace switch ($15 part)
good luck
Jun 17, 2011 | 1999 Chevrolet Cavalier
Oil pressure switch location on 1999 chev cavalier
The oil pressure switch relays the oil pressure in the engine to the instrument cluster. The switch will illuminate the OIL PRESSURE light if the oil pressure drops below 2psi (13 pa). The switch is usually located on the side of the engine, under the intake manifold on the 2.2L engine and on the side of the intake camshaft housing on the 2.3L/2.4L engine.
Fig. 1: The oil pressure switch is located on the engine block under the intake manifold and is accessible from underneath the vehicle-2.2L engine
Fig. 2: Oil pressure switch location-2.3L/2.4L engine
Other, the low oil level switch activates the OIL light in the instrument cluster when the oil level in the pan goes below a certain level. The switch is mounted on the oil pan.
Hope this helped (remember rated this post).
Apr 11, 2010 | 1999 Chevrolet Cavalier
My 2001 chevy cavalier has a oil leak and I can't
You can buy a florescent dye to add to the oil and a light to make the dye really shine.
Clean the engine with "brake clean" from a spray can at the oil leak areas ....then run the engine.
Check for the start location of the leak.
Start with a short run time ....... then longer run time if necessary until the leak(s) show.
With or with out the dye ......this brake cleaning method should help locate the leak(s).
Oil leak locations could be...in order of the most common on your car are........valve cover gasket,oil filter,oil pressure sending unit,drain plug,oil pan gasket,crank pickup sensor,rear seal.
Oct 14, 2009 | Chevrolet Cavalier Cars & Trucks
Location of oil pressure switch.
how change oil pressure sensor in 2001 mazda mpv dx
Apr 10, 2009 | 2001 Mazda MPV
Generac Guardian 0C3025 -  oil pressure switch Logo
1,836 people viewed this question
Top Generac Guardian Electrical Supplies Experts
jdthefixer
epangan29
ken skalski
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
