Question about Sony KP-46WT510 46" Rear Projection HDTV
BLUE TINT ON SCREEN ALL THE TIME, COLOR ADJUSTMENTS FINE
If u turn tv off then back on, tv works as supposed to. but after a few minutes of operation it reverts to the blue tint/haze.
this is very annoying, but seems to not bother picture clarity.
    Novelist:
  • 184 Answers
Sounds like a bad blue CRT (picture tube) ITs expensive and difficult to replace. CAll a Sony service center for an estimate. but expect to spend $500-700 to replace it.
michtech
Posted on Feb 19, 2009
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
RCA Tv color problem
try degaussing the picture tube
Jan 31, 2010 | Televison & Video
Video is taking on a red tint which is getting worse over time
check the cable connections. look at different inputs. VGA and Component cables have the colors split, so if it's turning red, green, or blue; it's likely a cable or connector.
Dec 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
BLUE TINT ON MY SCREEN
Philips tv's have always had this problem. Between the picture tube and focus lens there is a layer of coolant fluid. The coolant fluid, over time, will break down and turn a brownish cloudy color and it usually starts with the blue. Something to do with the color frequency. Have a good repair shop check it out and if the fluid is the problem have them change all the fluid in all 3 picture tubes (there is a red, green and blue tube). Don't feel bad, like I said all the philips projo's had this problem. Thanks
Oct 29, 2009 | Televison & Video
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Tv turns off, volume adjusts incrementally then shuts off, screen is tinted blue
there is a defecton the small signal panel. most of the time caused by power surge..john
Aug 30, 2007 | Insignia IS-LCDTV32 32 in. Television
Red Screen
first try going to the menu on the tv and adjusting the red blue and green tint....if not the u need to remove the front pannel and move the the the top left knob on the setting to lower the tint...
Aug 15, 2007 | Hitachi 57S700 57" Rear Projection HDTV
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Screen
What you may have needed to do was adjust the green & blue crt screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white px. Now adjust each crt screen so that you end up with a true black & white px. Then adjust each focus control to get a sharp px, have your tv on a channel like the home shopping network so you can adjust each crt focus one at a time for clarity by cover the other 2 up. Then go back into picure adjust & turn color ahlf way up, you should see a better px.
Jul 01, 2007 | Philips 60P8341 60" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
175 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
