Question about Canon PIXMA iP1600 Printer
How do you load the ink cartridge?
I see the slot but i don't see how it will hold the cartridge.
    President:
  • 2,692 Answers
How to replace ink cartridges
Instructions Things You'll Need
  • New ink cartridges
    • 1
      Turn on your Canon PIXMA MP150 printer. Lift the scanning unit and hold it open with one hand. Slide the support arm on the right side into the groove at the right front corner of the unit so that the scanning unit rests in an open position.
    • 2
      Apply pressure on the top front of the first Canon FINE ink cartridge with your finger until you feel the cartridge unlock within its slot. Pull it from the slot and set it aside for disposal.
    • 3
      Grasp the tape end hanging from the new replacement cartridge and remove it carefully from the cartridge without touching the ink nozzles or the gold electrical contacts.
    • 4
      Hold the cartridge by its sides in front of the slot with the electrical contacts facing away from you and the front of the cartridge angled down slightly.
    • 5
      Slide the cartridge carefully into the slot and then push up on the bottom front of the cartridge until you feel the cartridge lock into the slot with a click.
    • 6
      Repeat the replacement process with the second cartridge if you need to change it.
    • 7
      Lift the scanning until the support arm pulls out of the groove. Push the arm back into its original position
Aug 10, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    How do I load the ink cartridges into the Canon Pixma printer MX320?
    1. Make sure that the power is turned on, and open the Paper Output Tray.
    2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
    The FINE Cartridge Holder moves to the replacement position.
    3. FINE Cartridge.
    (1) Pinch the tabs and open the Ink Cartridge Locking Cover.
    (2) Remove the FINE Cartridge.
    4. Prepare the new FINE Cartridge.
    (1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
    5. Install the FINE Cartridge.
    (1) Put a new FINE Cartridge in the FINE Cartridge Holder.
    The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
    (2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
    Push down the Ink Cartridge Locking Cover until it clicks.
    (3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
    (E) Closed correctly
    (F) Not closed correctly (the cover is tilted)
    6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
    Oct 05, 2010 | Canon Office Equipment & Supplies
    Install black cartridge, but will not print
    Lets do it this way. Follow these steps again carefully and try to install the Ink.
    Introduction
    Follow the instructions below to replace the ink cartridges.
    Replacing the ink cartridges
    1. Verify that the unit is on.
    2. Open the ink cartridge door.
    3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch.
    1 - Ink cartridge latch for the black ink cartridge
    2 - Ink cartridge latches for the color ink cartridges
    NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
    4. Pull the ink cartridge toward you out of its slot to remove it.
    5. Remove the new ink cartridge from its packaging.
    6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted.
    7. Press down on the gray latch until it clicks into place.
    8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
    9. Close the ink cartridge door. Print a test page.
    If after doing this it does'nt work, then i will ask you to unplug the printer cable from the computer and uninstall the printer driver/Software completely.
    Shut down your computer and restart it.
    Re-install the printer driver/software from the start as you did when you bought it.
    Good luck
    Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
    How do you install ink into a hp c4180
    Hi bogtank, here are the instruction on how to install the ink cartridges.
    1. Open print cartridge door, make sure the print carriage moves to the right, if it does not move to the right, turn the device off, then turn it back on again.
    2. Remove the tape from both cartridges, making sure you don't touch the copper coloured contacts.
    3. Hold the cartridge with the HP logo on top.
    4. Insert the tri-colour cartridge in the left cartridge slot, and the black cartridge in the right slot.
    5. Make sure you push the cartridges in firmly until they snap into place.
    6. Make sure you have paper loaded in the tray and close the print cartridge door.
    7. Press OK at the promt on the display to start print cartridge allignment.
    8. Check the display for status then press OK.
    Nov 13, 2008 | HP Office Equipment & Supplies
    My HP photosmart C4200 ALL-in-One series is telling me is telling me that my print cartridge is missing or not detected, I just barely replaced the ink.
    Below is a partial entry of the help document at HP. The complete text can be found by clicking on this link here.
    If you have already read and completed these steps, please notify me that you have by using the Text Area Comment Box below. Proivde me with any thing else you have already tried. Lastly, do you have a manual for your printer in digital format that you can place on your PC and refer to? I can post one here for you if you need it.
    Essentially, there is no easy Trick to clearing this issue. The most common error made by users it in replacing both cartridges at the same time. Each cartridge should be replaced individually. Once completed the printer will want to execute a print head alignment test. This print out will include instructions on selecting the numbered lines that line up most exactly. Then you would enter the corresponding number.
    Bypassing or interrupting this alignment test after replacing cartridges will cause error messages such as yours. So, if you did this out of ignorance or confusion, remove each cartridge one at a time using the method descrbed below. When both have been removed and reinstalled and the alignment process completed you should be error free. Should you still receive this error, remove and clean each cartridge using the method described below, one cartridge at a time.
    If after completing all the steps below, you still receive the error message, your printer has a larger problem that is internal hardware related. You can either replace the printer or have it serviced by HP. Most people opt to replace the printer as an error such as this at the internal hardware level usually indicates that the printer has reached the end of its usable life span. If this is happening prematurely, have it serviced under warranty. Printer warranties are usually one year from HP. If you purchased using a credit card you may have an extended warranty. Check with your card company right away for information on any extended warranty you have from using your Credit Card.
    If you have any further questions, please ask me using the comment box below.
    Regards,
    Worldvet
    Solution one: Remove and reinsert the ink cartridges
    1. Turn the product on.
    2. Make sure to have letter or A4 unused, plain, white paper loaded in the input tray.
    3. Open the ink cartridge door.
      NOTE: Make sure that the carriage holding the ink cartridge moves to the right. If it does not move to the right, turn the product off. If it is a new product, make sure all the packaging material is removed. Close the ink cartridge door and then turn the product on again. The carriage should move to the right. Figure 1: Opening the ink cartridge door c01333689.jpg CAUTION: The product must be turned on before the ink cartridge door is opened. If the product is off when the ink cartridge door is opened for access to the ink cartridges, the product will not release the cartridges. The product can be damaged if the ink cartridges are not docked safely before removal.
    4. Wait until the carriage is idle and silent, and then lightly press down on an ink cartridge to release it. The error message should indicate the problem cartridge by displaying an icon that represents it.
      • The tri-color ink cartridge is in the slot on the left.
      • The black or photo ink cartridge is in the slot on the right.
      Figure 2: Pressing down on an ink cartridge to release it c01333690.jpg 1 - Ink cartridge slot for the tri-color print cartridge 2 - Ink cartridge slot for the black and photo ink cartridges
    5. Pull the ink cartridge toward you out of its slot.
    6. Make sure the tape has been removed from the cartridge. If the tape has not been removed, remove it now. Figure 3: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or reattach the tape.
    7. Hold the cartridge with the HP logo on top.
    8. Reinsert the ink cartridge into its slot by gently pushing the upper part of the ink cartridge forward until it clicks into the socket. CAUTION: When installing the ink cartridge, do not rest your hand on top of the product for leverage. This might cause the carriage to lift out of position. Figure 4: Incorrectly grasping the top of the product for leverage c01333691.jpg Figure 5: Pushing the cartridge in firmly c00853118.jpg
      • When installing the tri-color ink cartridge, slide it into the left slot.
      • When installing a black, photo, or gray photo ink cartridge, slide it into the right slot.
      Figure 6: Tri-color cartridge in the left cartridge slot and black cartridge in the right cartridge slot c00880896.jpg
    If the error message persists, continue to the next solution.
    Nov 11, 2008 | HP Office Equipment & Supplies
    New Cartridge error message
    Follow the steps below to remove and replace the empty ink cartridge.
    1. Turn the printer on.
    2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
    3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
      NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
    4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
    5. Remove the new ink cartridge from the packaging.
      NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
    7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
    after Doing this all Follow the next step :-
    Please Try This, I am sure it is going to workout.
    Resetting the All-in-One
    Press the On (fa37665.gif) button to turn off the unit.
    • Disconnect the power cord from the back of the unit.
    • Connect the power cord to the back of the unit.
    • Press the On (a477fdf.gif) button to turn on the unit.
    Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
    Loading the ink cartridge
    Please remember to rate other users who assist you for free :)
    How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
    How to install ink cartridges
    1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
    2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
    Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
    3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
    Note: Push up on the nearest side of the cartridge until it clicks into place.
    4. Confirm that the ink cartridges are installed properly.
    (A) The ink cartridge is not installed properly.
    (B) The ink cartridge is installed properly.
    5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
    How to remove ink cartridges
    2. Remove the ink cartridges.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    How to load the new ink cartridge. HP Photosmart C5140.
    Replace the ink cartridges (from the manual for the printer)
    Follow these instructions when you need to replace ink cartridges.
    To replace the ink cartridges
    1. Make sure the HP All-in-One is turned on.
    2. Open the ink cartridge door by lifting from the front center of the device, until the door locks into place.
    3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch. If you are replacing the black ink cartridge, lift the latch on the far left.
    If you are replacing one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    5. Remove the new ink cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot. Make sure that you insert the ink cartridge into the slot that has the same shaped icon and color as the one you are installing.
    6. Press down on the gray latch until it clicks into place.
    7. Repeat steps 2 through 5 for each ink cartridge you are replacing.
    8. Close the ink cartridge door.
    Jul 04, 2008 | HP Office Equipment & Supplies
    How do I install an ink cartridge? HP photosmart c5280 All in one
    To replace the print cartridges Perform the following steps to replace the print cartridges:
    1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
    2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
    3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
    4. Pull the print cartridge toward you out of its slot.
      NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
    5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
    6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
    7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
    8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
    9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
      NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
    10. Press OK to continue.
    May 15, 2008 | HP Office Equipment & Supplies
    Canon PIXMA iP1600 Printer Logo
    32 people viewed this question
    old marine
    old marine
