Question about Hotpoint First Edition WMA12 Front Load Washer
No water coming in
On program e yet water comes in on program k
  • pedropony2 May 11, 2010
    could you confirm model plz.
  • 135 Answers
Hope your problem was solved.
Posted on Mar 15, 2009
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Water not coming
Possible that the inlet valve has failed , check the voltage to inlet valve to confirm that the program controller is working.Please check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Mar 14, 2012 | Bosch Washing Machines
Why does the washer start moving before the water is filled? Before the water would fill before it starts? Its only a year old.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle with the water level sensor working to the preset level. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor.In this case it seems that the level sensor is triggered to come on before as there is a false setting or fault on the sensor which can be the suspect.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 23, 2011 | Maytag Centennial MTW5800TW Top Load...
When I start the AEG 74950 washing machine, everything looks ok but the water it is not coming in
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Jul 26, 2011 | AEG Washing Machines
Washing machine water continue to come into the bowl and the cycle for spin etc seems a problem of sensor,i d'ont know with the LG fuzzy logic washing machine.May be to reset it,HOW?
Jul 05, 2011 | Washing Machines
When I hit the Americano button, it comes out like an espresso, not enough water comes through. I've just descaled. How to fix?
The amount of water is programmed by holding in the button. Put your cup below, and press the button. Keep holding until you are happy with the amount of water that came out - and then let go.
Next time you use it, you just need to do the normal short press on the buttom.
(Both the Espresso and the Lungo button can be programmed.)
Jul 31, 2010 | Nespresso Le Cube
Water still in drum after programs finished.
This is caused by the water level switch not working correctly. This is most commonly caused by the internal filter being blocked, you need to remove the filter and clean out all the buttons coins and lables ETC , see the note on how to do this from other user
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Dishwasher gets stuck after first rinse
all programs start with drain put a little water in by hand, start a program and see if water comes out of the drain hose. things to check are if drain hose is plumbed in under sink, check no blockage in this area. if drain hose not running, then listen carefully for a low humming noise. if there is, this indicates a foreign object stuck in drain impellor. if youhave a multimeter, check if there is power to the drain pump
Jun 19, 2007 | Miele 24 in. G693 Free-Standing Dishwasher
Hotpoint First Edition WMA12 Front Load Washer Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
