Question about Canon imageRUNNER C3200 Color Printer
IR C3200--DISPLAY BOARD SHUTS DOWN ---TURNS BLACK
  • 4 more comments
  • Sonny Rimatello Mar 14, 2009
    Yes --the power green light is still on
  • Sonny Rimatello Mar 15, 2009
    Thank you I will give them all a try
  • Sonny Rimatello Jul 28, 2009
    Yes the green light is on and stays on even when the panel board goes black
  • Sonny Rimatello Jan 28, 2010
    My canon shows error code--E000020-0160
  • color_50
    color_50 May 11, 2010
    does the control panel ever come on when u power up printer ?
    Sorry I have to ask this but you do know there is small flat button on panel that can adjust panel contrast from black to bright.If that is ok try the issues below.
    Check for a tripped or blown breaker on the back of the Reader unit.
    Check your fuse pcb.voltages/ & voltages on power supply=J254E, pin 3 needs 3vDC
    Check back to the Low Voltage Power Supply at J302E, pin 3 for 3vDC
    Check wall voltage between the neutral and ground must be 1/2 a volt or less.
    Try and re-seat Dimms on main pcb.
  • color_50
    is green power light on ?? when does it shut off ??
    Sniper:
  • 77 Answers
May be your hard disk failure
Posted on Aug 01, 2010
  • 149 Answers
Sounds like you may have a faulty LCD screen
Posted on Jul 06, 2009
Canon IR C3200 - Error E000020 0170
Fault connected withdrum/developer,in this case yellow(E.020-0170)
...-0270 is magenta,...0370 cyan and ....0470 black.
Apr 17, 2013 | Canon Ir C3200 Color Copier netfax N-1...
Clc 3220 paper jam message
Is the display showing a jam in the fixing unit??? Did you l open and close all the doors & covers???? I have found that there is a plastic Exit flag on the small door that folds down on the fixing unit. It is plastic and it can break very easy. You may have to replace the flag. If you have another IR-C3220 try to switch the units with each other copier. The problem could also, be the black connector on the unit or in the copier, it may be broken... It is not easy to change the one inside the copier..... Good Luck
Jun 05, 2012 | Canon imageRUNNER C3200 Copier
Samsung mobile gt-c3200 no display only white light
samsung gt-c3200 on disply, LED of problem
Apr 12, 2012 | Samsung Cell Phones
How do I find the re-maining drum life on my Canon IR C3200 copier
Get into service mode by depressing the Additional Function key, the 2 and 8 keys at the same time and then the Additional Function again. You should then see a menu of options. Press the COPIER key, it will highlight. Then display a new set keys across the top of the display, then press DISPLAY, then MISC then see DRM-LF. The number is dipslayed as the % of life left in the drum. Most of the time the drums go further than 100%. The copier will then indicate an error code such as E020-04B0 when the drum is failing. The first two digits after the dash indicate the drum 01 - Yellow, 02 - Magenta, 03 - Cyan, and 04 - Black. Be careful in service mode, it can really get you into trouble if you don't know what you're doing. Good Luck
Jun 14, 2011 | Canon imageRUNNER C3200 Copier
Tried the solution to set black as the default color on the Canon ir c3200 that was on your site, it says to set as B/W on screen, only gives Auto Color Select, Full Color and Black as choices. Says to go...
might be able to do this through your remote user interface {the copier ip address} go to internet expolrer and type the ip into the address bar and look around for settings under additional funtions
Mar 26, 2010 | Canon imageRUNNER C3200 Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
CANON IR C3200
Hi there, your printer is experiencing a shortage due to a lose connection that's located on the backside of the control panel. you will have to disassemble and remove this control panel to find this lose connection. this connection seems to be linked to the power board which explains why the screen turns black.
Feb 18, 2009 | Canon imageRUNNER C3200 Color Printer
Canon ir c3200 promts for page setup on each internet document
I believed when page setting box show out you have to enter the quantity you want print
Dec 09, 2008 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER C3200 Color Printer Logo
310 people viewed this question
old marine
old marine
