GE washer (wjsr4160gww) makes loud noise during spin cycle
My washer makes loud vibration noise during the spin cycle. I thought I might have overstuffed the washer, so I emptied the washer and ran the spin cycle. But, it still made very loud noise.
Also, I did a small load of laundry, resulting in soaking wet clothes.
Do you think it is an agitator problem?
Thank you.
  • Anonymous Feb 28, 2009
    I have the same problem. Machine vibrates very loudly during spin cycle. Starts moving across the floor. Pulls drain hose away from slop sink. Water spill son to the floor. How do we stop all the vibration and noise. ?
  • NeedsHelp85 Mar 07, 2009
    I have the same problem! I balanced the clothes...noise was still occurring. I live in an apartment so I'm sure my neighbors can hear it. It's ridiculous! I called customer service and they told me to balance the clothes and the noise is normal. I said I did that! Do they really think that I would call if I could fix the problem that easily? I even ran it with no clothes in it and the noise was slightly less but still much louder than usual. You're jumps all over the place! I'm afraid it's going to cause damage to the walls and then I'll have to pay to fix it!
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Posted on Mar 12, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
Noise during spin cycle
what noise is it making, it may just be off balanced
Jan 17, 2012 | GE WSXH208A Front Load Washer
Loud knocking during spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
Aug 21, 2011 | GE WSXH208A Front Load Washer
Washer makes loud noise during spin cycle
Check out this tip I wrote about the noise and vibration that front load washers can make..
Aug 31, 2010 | Kenmore 4292x Front Load Washer
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Nov 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Washing Machines Logo
4,328 people viewed this question
Top Washing Machines Experts
